Opinions on a TC25
   / Opinions on a TC25 #1
double hunter
Ford 1715
Im looking at a TC25,,just looking for opinions good or bad, ,,looks to be in good cond, 1300 hrs,,runs good,,will it pull a 5' rotary cutter and disc
   / Opinions on a TC25 #2
It has either 20 or 18 HP at the PTO. I've haven't seem a 5' rotary cutter rated less than 25 HP at the PTO, but if you are cutting just grass it might be OK. It might pull a small disc depending on how aggressive it is setup to engage the ground.
The TC25 is the lowest HP in the 60" wide New Holland CUTS.
   / Opinions on a TC25 #3
Had one years ago nice small tractor with hydro somewhat under powered
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2018 Kubota...
Van's Equipment Company Sprayer (A57454)
Van's Equipment...
Electric Golf Cart (A56859)
Electric Golf Cart...
TANK MANIFOLD (A55745)
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A56859)
2009 Skeeter SL190...
