Opinions on Cummins 5.9 Diesel
   / Opinions on Cummins 5.9 Diesel #71
But that couldn't be put in a P/U truck, a DT can. That's also no longer the "most powerful" engine anymore. Last time I talked to a Wartsila mechanic he said their flex line is now the most powerful. I was actually on one of the 96-C's a few weeks ago in the Baltimore docks. Quite a impressive machine to see in person.
   / Opinions on Cummins 5.9 Diesel #72
It's factory set at 210, but I put the 250 pump, turbo & injectors on it and she churns out a lot more now. I have also played with the pump, timing and governor springs. I'd guess it's about 275/800 right now by the way it pulls compared to when I first got it. :)
I forgot to ask, does it have a side-by-side air-to-air or a full size one in front of the radiator.
   / Opinions on Cummins 5.9 Diesel #73
Apples to Oranges? Just because Dodge had the good sense to use a commercial grade engine in its heavy duty trucks doesn't mean they shouldn't be compared directly with the lessor competition. IMO. I own a 06 2500 w/ Cummins. It is the ONLY truck you should consider for serious hauling. I am a commercial driver so I know a thing or two about heavy trucks. And by the way , its hardly "shoehorned in" I bet I have as much or more room under the hood as you do!
   / Opinions on Cummins 5.9 Diesel #74
Full size CAC in front of radiator. She runs really cool even turned up. I have the pyro tip mounted in the ex. manifold and she won't go much over 1150 fully loaded on hills. I thought of maybe porting & polishing the head for more power.
I think we better not hijack the thread anymore. ;)
2016 Ford Edge SUV (A56859)
2016 Ford Edge SUV...
2006 Toyota Tundra 4X4 Pickup Truck (A53422)
2006 Toyota Tundra...
JLG 460 SJ TELESCOPIC MAN LIFT (A52707)
JLG 460 SJ...
CATERPILLAR CP44 PADFOOT ROLLER (A52707)
CATERPILLAR CP44...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A55973)
2007 Reitnouer 40...
JOB BOX W/ 100K X 20' NYLON SLINGS (A54757)
JOB BOX W/ 100K X...
