KWentling
Veteran Member
- Joined
- Jun 22, 2002
- Messages
- 1,176
- Location
- Rozet, Wyoming
- Tractor
- Kubota BX22, Kubota ZD21, Kubota M7060
How can you replace one spool for a motor application? Do you mean an internal modification or just add an external motor valve? I believe this valve came originally from a BH.[/QUOTE]
If it is a sectional valve (bolt together sections), a motor spool valve could be added or substituted. If it is not sectional, it might be possible to just replace the sliding spool inside the valve body with a motor spool. You would have to contact the manufacturer or a shop that deals with that brand of valve.
Not sure I understand the purpose of the check valve Farmerford mentions. If the PTO does not stop too abruptly when disengaged, that would work OK.
Kim
Kim
