ORB to NPT
   / ORB to NPT
ORB and JIC are the same pitch and diameter. In a pinch you can use a male JIC fitting with an 'O' ring on the shoulder to fit into an ORB port. You might have to cut off the taper if it's too deep.................Mike
Good tip thx!!
   / ORB to NPT #12
Just a side point:
Since we are getting a bit technical with term like NPT/NPTF/SAE/ORB/JIC
Just thought I would mention one more "technicality"
"NPT Vs. NPTF Taper Pipe Threads
... NPT threads are for mechanical or low-pressure air or fluid applications and require the use of sealing compounds like Teflon tape, to provide the seal....
Actually, there is no such thing as Teflon Tape. It is more correctly called "Plumbers/PTFE/Thread Seal" Tape. Teflon is a Brand Name, not a product or substance. It used to belong to DuPont and now is the property of Chemours - and neither company makes plumbers tape - therefore, technically, since the owner of the name "Teflon" does not make it, Teflon Tape does not exist.
I copied that from the internet
Just goes to show that not everything on the Internet is 100% correct.
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
John Deere Metal Sign (A57454)
John Deere Metal...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
2012 Western Star Trucks 4900 SA Truck, VIN # 5KJJALDV0CPBE2239 (A57453)
2012 Western Star...
2014 Freightliner M2 106 Bucket Truck, VIN # 1FVACXDT2EHFU7070 (A57453)
2014 Freightliner...
