Ordered my Bush Hog M246 FEL
   / Ordered my Bush Hog M246 FEL #41
You better take and post some pictures for us before you start that tractor up. Once you start using that new FEL I think your going to be out there for a while and I don't want to wait that long for pictures. If your brave enough have your wife take a picture of you by your tractor so we can all put a face to the name.
I'm pretty confident I'll be getting the tractor back today or tomorrow - it's raining and the forecast is for rain all through the weekend! I guess I'll just park it under the carport and raise the bucket up and down. I think I'll have plenty of time for pictures before I can do any work with it.
   / Ordered my Bush Hog M246 FEL #43
Danny,
Thanks for the pics. That will work great for what we need. We may need a longer reach.
murph
My Boomer is back and the FEL is on. I was relieved that the control stick does not interfere at all with getting on and off the tractor from the right hand side. The color match was close, but not exact, certainly good enough. The mounting bracket was not like I expected though. There is a bar that runs from the mid point to the front of each side and they do not come off when the loader is detached, and they get in the way of checking the oil and will make maintenance more difficult. The pop off side panels will still come off. The bars come off with only 5 bolts each if I need to get them out of the way. There are also some brackets underneath that go from the mid point to the rear axle, which won't be a problem except I'll have to redo the bracket I made for the break back arm on my sickle mower. This loader is definitely not going to be compatible with a mid mount mower. It operated very smoothly and goes really high. When it dries off I'll test it under load.
Note: The red in the background is a crab apple tree, and the purple farther back is red bud trees. I don't know who named them, but they were color blind!
Another picture.
   / Ordered my Bush Hog M246 FEL #46
It certainly looks like it has a lot of reach! I know that despite the small issues you have with it you will get a lot of use and enjoyment out of it. Like other folks have said, you're gonna wonder how you made out without it!
Crabapples and redbuds abloom and you in a short sleeve shirt... guess it is finally springtime up your way! Good timing to get in some quality seat time. /forums/images/graemlins/cool.gif Now all you need to do is add your FEL to your profile! /forums/images/graemlins/wink.gif
   / Ordered my Bush Hog M246 FEL #47
Congrads! Your tractor just got about 80% more versatile.
Enjoy... /forums/images/graemlins/cool.gif
   / Ordered my Bush Hog M246 FEL #48
Danny,
Congrats! You'll love it!
Spring refuses to come to New England 25 degrees this morning!
Enjoy & keep the pictures coming.
   / Ordered my Bush Hog M246 FEL #49
Mosey, in the first picture I notice that your FEL has a much greater rollback angle than mine. The 7308 starts out with a measly 20 degree rollback angle but I lost 5 precious degrees adding the Kasco Unihitch. When you get a chance I would love to see a close-up of your quick-tach setup. I also notice that huge guard in front of your hood. Did that come with the loader or did you already have that.
In the second photo I can see that your loader has two braces inbetween the loader arms where the 7308 only has one. I also notice that your loader arms appear to be almost straight up and down. I will have to check my 7308 but I don't think mine go up to almost vertical. Again that rollback angle looks great. Just be careful when you have a load in that bucket up that high, it looks like it might rollback right out of the bucket and onto you and your hood. Overall it looks like everything about it is better than the 7308 so I think you made the right choice, enjoy and get some action shots when you can.
Well, I'm getting use out of the FEL already. Attached is a picture of a rock I unloaded from my pickup and put in place.
Spencer, The grill guard came with the package. I'm not sure what the lift height difference is because according to the brochures I got, the lift height for the NH 7308 is 100.8" but it doesn't say where that's measured and the BH M246 is 103" and it says that's to the pivot pin. The dump angle on the 7308 is 39 degrees and on the M246 is 40 degrees. The rollback angle on the 7308 is 20 degrees and on the M246 is 25 degrees. The lift capacity at the pivot point on the 7308 is 875 lbs and on the M246 is 1530 lbs. But, with the added lift capacity, the FEL also weighs more. The weight of the 7308 is 839 lbs and the M246 is 1453 lbs.
Actually, I would have preferred the NH 7308, even though the BH M246 has a few better specs. If I could have gotten the 7308 for the same price as the M246 or close to it, I would have gotten the 7308, but $1000 more was too much. I really don't need the added lift capacity and would have preferred the lighter weight and the mounting brackets not being so much in the way. With the added weight of the mounting brackets, I certainly don't need the 2 front weights anymore (total of 65 lbs).
The dealer had left the installation manual for the FEL in the tool box, but there wasn't an operator's manual. I'd like to detach the FEL, but I'm not sure how to do it. I'm also missing the bucket level indicator. I need to call the dealer and get the missing manual and indicator.
The FEL is heavy and makes the tractor "feel" heavy I had to add air to the front tires. I added 6 quarts of hydraulic fluid to the tractor, since the loader cylinders and hoses sucked up a lot. Then, I used the loader to unload a large rock from the pickup. It was too heavy to roll or tip it into the bucket, so I wrapped a chain around the FEL bucket (I can see I need to get some hooks on the bucket). I didn't have anything on the back of the tractor, so when I went to lift it up, the rear wheels came off the ground! So, I went and hooked up the finish mower and then was more careful. This time it was no problem. I already weighed the pickup with the rock in it, so I'll weigh it again next week and find out what the rock weighs.
Michigan rock in Indiana. The white spruce tree also came from Michigan.
I went back to the scales and weighed the pickup empty. The rock weighs 870 lbs! Much more than I thought. I got my manual and bucket level indicator. They just forgot to bring them. I detached the loader and it's as easy as advertised. I didn't have time for pictures because I needed to get the grass mowed, it was starting to look like a hayfield. I'll get some pictures of the FEL detached when I get a chance.
   / Ordered my Bush Hog M246 FEL #53
</font><font color="blue" class="small">( I went back to the scales and weighed the pickup empty. The rock weighs 870 lbs! Much more than I thought. I got my manual and bucket level indicator. They just forgot to bring them. I detached the loader and it's as easy as advertised. I didn't have time for pictures because I needed to get the grass mowed, it was starting to look like a hayfield. I'll get some pictures of the FEL detached when I get a chance.)</font>
Mosey, I know it is a stupid question but did you have the same amount of fuel, people, etc. both times you weighed?
</font><font color="blue" class="small">( Mosey, I know it is a stupid question but did you have the same amount of fuel, people, etc. both times you weighed?)</font>
Spencer - I'm an engineer, so I made sure to account for everything! I didn't drive the truck much, since it had the rock in it, so I only used 2.5 gal of gas and assumed about 9 lbs per gallon (I weighed a gallon of apple juice in a plastic container and guessed that gasoline would be close to the same weight), so I added 22 lbs to the empty weight. I was in the truck both times when they weighed it. I know 870 lbs seems like a lot for that size rock, but it's true! When I get a chance, I'm going to get a full bucket of wet dirt without any ballast and see if it also brings the rear wheels up when I try to lift it. I will be careful!
   / Ordered my Bush Hog M246 FEL #55
</font><font color="blue" class="small">( </font><font color="blueclass=small">( Mosey, I know it is a stupid question but did you have the same amount of fuel, people, etc. both times you weighed?)</font>
Spencer - I'm an engineer, so I made sure to account for everything! )</font>
Mosey, I was just surprised that it weighed that much. It's hard to tell these things from photos. Your rock looked similar in size to a rock I have here. I transpanted it today for the wife into a new flower garden I made for here. I picked it up at the end of my 48" forks. I estimate the center of the rock being over 36" away from the pivot point where my 7308 is rated at 880 pounds. So with my rock being at least 36" further out from the pivot point, my 415 pound forks mounted on the loader, and my Kasco Uni-Hitch also on the loader I just figured that my rock couldn't weigh over 400 to 500 pounds. Take a look at my rock in the attachment and tell me what you think.
Spencer - I really don't understand it either. Did you have any ballast on the back of your tractor? Can 2 men roll your rock over? My brother and I could not roll my rock over. When we loaded it we used his Satoh tractor to drag it because he couldn't pick it up with a rear bucket (he has a homemade rear bucket similar to a rear scoop, but 5' wide). We were able to lift one side of it enough to get a nylon rope under it to lift it. We put the snatch block for the winch on a big tree branch and picked it up with a 8000lb winch.
   / Ordered my Bush Hog M246 FEL #57
<font color="blue">...we used his Satoh tractor to drag it ... </font>
What model Satoh does he have? A number of the smaller Satoh's have very weak 3-pt. and only lift a few hundred pounds working normally...
<font color="blue">… I'm an engineer…</font>
Danny, I'm curious… What kind of engineer are you…?
JohnMiller3 -
What model Satoh does he have? If I remember right, it's a 650G. The problem was not the power of the 3pt, it was the lack of weight. It has an aluminum engine and it's 2WD, so there's not much weight up front. It can lift a King Kutter 5' tiller and a Bush Hog 6' finish mower with no problem, and those weigh over 650 lbs.
What kind of engineer are you? Digital Electronics (did some VLSI for a while), Software (UNIX, C), and now doing Systems and even some web design at Cummins (see www.mininggateway.com).
Here are some more pictures. First, FEL detached.
Tractor with FEL detached. The part that stays on the tractor weighs over 400 lbs.
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2015 CATERPILLAR  XQ30 GENERATOR (A58214)
2015 CATERPILLAR...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2020 INTERNATIONAL REEFER TRUCK (A58214)
2020 INTERNATIONAL...
Informational Lot - Financing (A56438)
Informational Lot...
