ordering trailer -sanity check please
   / ordering trailer -sanity check please #21
I don't think that's true for a gooseneck or 5th-wheel. Bumper pulls have 10-15% tongue weight. Gooseneck and 5th-wheel have 25%. Don't ask me why, though.
Interesting that a GN would be *higher*... I would expect it to be lower since the attachment point is further from the axles. Must have something to do with either the extra weight of the trailer to provide the GN setup, the location of the axles in relation to the trailer length (further forward?), or both.
I don't know much about them, though, and I was commenting on weight bearing for a bumper-pull setup.
   / ordering trailer -sanity check please #22
My guess is that it is because a GN attaches to the truck closer to the axle, so leverage is less of an issue. Not sure why less tongue weight would be a problem, though. Bumper pulls are typically 10-15%; GN are typically 15-25%. So why can't a GN go down to 10%?
   / ordering trailer -sanity check please #23
My *guess* would be that, since the trailer is capable of more directly placing load onto the truck axles, the trailer is designed to reflect this. Dropping pin weight on a GN to the 10% area could mean that there's more weight than appropriate behind the rear trailer axle, causing a poor towing condition.
   / ordering trailer -sanity check please #24
You are making broad-stroke statements that are NOT accurate. I have already shown your generalized statement to be incorrect when you said that a WDH was required based solely on size and weight.
While your "answer" was correct, your reasoning was not. I am trying to point out that you "did the math" for him and make a generalized statement that doesn't hold water. Specifically, for this posted, with this trailer, and this tow vehicle, and WDH is required for a bumper-pull trailer.
No my broad statement is accurate, and based on well known data. With 1 exception, there is no manufacturer of light duty trucks for sale in the US that does not require a WDH for loads above 5,000 lbs gross / 500lbs tongue. The only exception I know of is F350 with dual rear wheels, where the limit is 6,000 lbs.
My truck is not rated to pull a trailer that heavy. If stay within the 10k rating, though, I do not need a WDH because my truck is rated for the tongue weight. The need for a WDH for a particular trailer / load is based on the TOW VEHICLE'S max tongue weight rating, and NOT something that can be ascertained solely from knowing the size and weight of a trailer.
Your tundra should be rated for 5000lbs trailer/500lbs tongue weight when equipped with the factory hitch/tow package. Yes it can tow more, but not without a WDH sized for the trailer and tongue weights.
This is an incredibly important point to understand because it allows for the purchase and use of the CORRECT WDH as it will be rated to handle a specific amount of tongue weight.
Absolutely, you need to select the right components for the trailer you plan to tow.
   / ordering trailer -sanity check please #25
I have a 3/4 ton GMC that has a sticker on the hitch saying it is good for 1000 pounds tongue weight and 7500 trailer weight.
   / ordering trailer -sanity check please #26
but to know about weight carrying, or distributing you'll have to goto the owners manual or towing guide for that model.
   / ordering trailer -sanity check please #27
Once again, broad statements that are WRONG because they don't include defining information. The REASON that Class IV hitches are rated with a max of 500lbs tongue weight is because of the way they are bolted to the vehicle. My truck uses a frame-integrated hitch the gains the bulk of its vertical support by being inserted THROUGH the frame. My tongue weight is NOT limited to 500lbs, my max trailer weight is limited to 9800lbs due to the options and trim level of my truck.
Clearly, we're on opposite sides of this discussion. I'll stay on the "Less" on side.
   / ordering trailer -sanity check please #28
Some of the Fords with the 6.7 are higher now. Around 8k IIRC.
Also, the 2011+ GM HD trucks do not require a WD hitch. :thumbsup:
   / ordering trailer -sanity check please #29
I use F250 and F550 trucks to pull my trailers and find that the WDH is very helpful for the F250. The F550 seems to handle very well with the 12k and 14k trailers without the WDH using just the Class 5 receiver. From my own experiences with the F250 I would plan on using the WDH and steering stabilizer on all bumper pulls 10k and up.
Most GN and 5th wheel trailers I have used were setup for about 25% tongue weight, a good reason for keeping it near this rating can include maintaining enough traction on the tow vehicle. When you park a heavy trailer/truck combination on a slope you need enough weight on the rear axle of the tow vehicle to hold it secure. You should chock the wheels on the trailer but if driving alone you need to be able to get out and do it.:eek: Now obviously a bumper pull with a heavily loaded trailer will have some similar issues too, when you stop in a 2wd pickup you have brakes on one axle holding the entire rig. Just something to think about.
   / ordering trailer -sanity check please #30
Can you elaborate on this? Are you referring to applying the emergency brake when the truck is parked?
JMR 96in Forklift Safety Basket (A56857)
JMR 96in Forklift...
2001 Ford F-650 Water Truck, VIN # 3FDWF655X1MA82619 (A57453)
2001 Ford F-650...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2012 PETERBILT 388 WINCH TRUCKS (A58214)
2012 PETERBILT 388...
Hydraulic Floor Jack (A59076)
Hydraulic Floor...
2014 Audi Q5 AWD SUV (A56859)
2014 Audi Q5 AWD...
