ordering trailer -sanity check please
   / ordering trailer -sanity check please #31
Can you elaborate on this? Are you referring to applying the emergency brake when the truck is parked?
Yes, when you park your emergency brake is all you have to hold truck and trailer is the truck's rear axle. Big rigs intended for full time trailering can lock up everything with air brakes.
   / ordering trailer -sanity check please #32
Gotcha. I thought that was what you were referring to but wanted to be sure.
Do any of the brake controllers have a "park and hold" mode? Mine will add trailer brakes while you're sipped and have your foot on the brake pedal, but it releases once your foot comes off of the pedal.
   / ordering trailer -sanity check please #33
Most light vehicles do not have any provision for holding the brakes on trailers when you exit the vehicle. All the electric drum brakes need the wheels turning to be very effective in pulling the brake shoes into contact with the drum. I wouldn't stake my life on these things holding either.
Point is the tow vehicle needs some weight or weight transferred to the rear axle to be safe on inclines.
   / ordering trailer -sanity check please #34
Althougth I agree that most comments are accurate based on information given. Here's where I have a rub on these statements. Each poster has specified a particular vehicle and that's fine. In my case my manual specifies that I can tow a 13000# load on my bumper and close to 16000# with a GN. My manual doesn't really mention a WDH but it's probablly there. My comments with a GN load verses a bumper pull load is this. A GN load may not increase your pulling ability but the stability is a major factor. I much prefer GN over BP for the stability it provides. I've experienced much greater trailer sway with a BP. As such except for a smaller load I've outfited my trailer arsenal with primarily GN, I just feel safer towing. Each to there own. As far as the WDH over non is this. What you feel is comfortable for you is what matters. IMO it's ultamately up to the operator and know what they're capable of.
   / ordering trailer -sanity check please #35
I really wonder how they calculate whatever they put in the manuals. My dad had a '73 3/4 ton Dodge. Had a 360, 4 speed, and 4.73 rear end. I have no idea what it was rated for. Yet in about 77, he bought a gooseneck 14 foot grain trailer. I hand stacked it with wheat out of the combine one time and went straight to town. I jumped out and they weighed the combo at 29,960 lbs. This was the heaviest load I think we ever had, but it was almost always between 27,000 and 29,000 lbs. It would take a while, but it would get up to 55 ok.
Now they have these turbo diesels and rate them for a 20,000 lb trailer or less. If those diesels can't out perform that old 360, I'd be might surprised. :confused:
   / ordering trailer -sanity check please #36
Keep in mind that a WDH is for dealing with TONGUE WEIGHT which is different than GTWR towing ratings. In order to understand if you need a WDH or not, you need to do two things:
- Calculate tongue weight. 10%-15% of the loaded trailer weight is the way to approximate, and you need to consider the *total* weight of the trailer and the cargo.
- Find the spec for your vehicle in terms of what it can handle for the tongue weight
This will get you along the path of knowing whether you need the WDH or not.
   / ordering trailer -sanity check please #37
The issue is not usually the engine being able to pull the weight but the brakes being able to stop it.
   / ordering trailer -sanity check please #38
OK, that part makes sense and I guess I've known that all along. This old beast had an aux brake unit plumbed in as opposed to the new all electronic units. We never had to slam on the brakes under full load, but running empty, it almost seemed to stop faster than w/o the trailer. The brakes on that trailer were outstanding.
2024 8x22 Enclosed Trailer (A57453)
2024 8x22 Enclosed...
2010 GLOBAL TRI AXLE HAUL TRAILER (A58216)
2010 GLOBAL TRI...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2015 Chevrolet Equinox SUV (A56859)
2015 Chevrolet...
WOOD GRABBER FOR MINI EXCAVATOR (A58216)
WOOD GRABBER FOR...
2025 Swict 66in Bucket Skid Steer Attachment (A56857)
2025 Swict 66in...
