Our brand new little kubota that....
   / Our brand new little kubota that....
Yes, I was referring to Pugwash N.S. Canada.
Is it safe to assume this stump was hardwood stump?
If you run into another stump like that you will
probably need a chain or two to secure the backhoe
to another tree.
Ok well I'm about 3 hours drive from Pugwash here and the stump was from a red pine. The scary thought I have is this. I have a BIG white pine to cut down sometime yet and it shares the same stump as a red pine about the same size as the one that this stump came from. So its gonna be a BIG hole and a few hours digging. I think the white pine alone I'm guessing has about 3 cord of wood to it lol. Sometime if I get the steel I wouldnt mind making a ripper tooth for the hoe to rip the roots of stumps so I could just flip them out of the ground.
   / Our brand new little kubota that.... #22
Once you remove the cover AJRaptor just pull the levers and you'll see the two sets of valves and therefore the hoses that have to be swapped. It is just a long valve body in there and they all look the same some verifying on your machine is best. You will need an 18mm wrench I believe to do the work. The bottom ones are a little tight but I can do the swap without having to remove any additional lines on my B26.
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
2010 Chevrolet Malibu Passenger Car (A51694)
2010 Chevrolet...
2006 CATERPILLAR 312CL EXCAVATOR (A51406)
2006 CATERPILLAR...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
