Our Tractor was delivered today
   / Our Tractor was delivered today #61
Stay away from pond edges. You may not be lucky enough to learn why. Please stay away from pond or lake edges. Good luck and congratulations.
Good advice, appreciated!
   / Our Tractor was delivered today #63
One thing I have yet to find in the manual is how to relieve the hydraulic pressure. It says to do this several times in differing scenarios of disconnecting and reconnecting the hoses. But it never says how to do it.
Then there is the issue of it, in several instances, running down a list of how to do certain things, and instead of finishing by telling you right there on that page what to do, it gives a section within the book to find it in. So far every single reference has been wrong.
Unreal.
So I did find the correct pages, and wrote them in by hand to supercede the wrong info.
That said, the salesman, nothing against him, but he didn't have much product knowledge. In fact, there was little effort given to show us features or operations. It's the old "We sold you the product, pocketed the money, you're now on your own."
I do, however, understand there are many makes and models there, but then again, that's his job. (BTW I sold Chevy's for years, and knew the packages and models very well.)
All this is SOP. No one ever told me anything unless I asked and there is a presumed knowledge of things in that business. If there was a nuke launcher button on it, someone might say "don't touch that" and figure you knew what he meant. Sure they want your $$ but if it was a Rolls Royce tractor, they still wouldn't say much.
In this regard, check all your fluids. The front axle will be low, because they all are. Check everything because likely no one else did.
The odds of getting in trouble with owning it decreases dramatically with each day you own it, even if you aren't using it. Somehow, machinery does so much work, and varied things, that knowledge flows from it. Just take it easy and if you aren't 100% sure you should be doing something, don't do it until you know more. At least till the training wheels are off. Stay away from edges of slopes until you bone up on rollovers.
There are times you will want to do "just a little bit more" and maybe push something beyond the comfort level. Don't do it until you know more. This is how loaders get bent or damage to you or tractor happens.
Keep kids off and away for quite a while and never, ever, ever while using an implement like a mower. Things that can go wrong do go wrong. Watch the height of the ROPS and tell the wife in advance you plan to rip off some branches. If you have a loader, it's longer than you think and you can easily clip a building. Of course, I never did. :whistle:
Other than that. you could go out and scratch it so you don't feel so bad when you do. Congratulations on reading the manual and asking questions. Things will go wrong but most will go right and you should have a wonderful time. Note that we will need lots of pictures.
   / Our Tractor was delivered today #65
I bought my Deere 955 knowing about zero about compact tractor operation. After 15 years: I can say it takes a bit to learn your tractors personal space so stay away from damage able stuff like buildings, cars etc. when I kissed the house with my bucket while mowing I not only crunched the clapboards but the sheathing behind it. Since you missed even the delivery guys input you should try to locate some neighbor farmer with blue tractor experience to spend a beer or two going over your tractor and operating tips. I haven’t seen what you are trying to do with this tractor but the low load height carrying advice is critical. Consider adding beet juice to your rear tires if you plan to dig and lift a lot with your loader. Some additional implements are not only brand but model specific so consider this aspect when buying more; you will be locked into that model or have to sell it all and start over with a newer model. As I wore out my first 955, I ended up buying another for that reason.
   / Our Tractor was delivered today #66
"kissed" the house. 🏆 That describes it and look at the damage done. When you are close to building, you can do incredible damage with 1/16".
I almost caught the corner of a shed with a 100 HP loader tractor with weights all around and behemoth radial tires. Had I hit the corner I would have taken some or most of the building down. Close gets no kudos with machinery.
Also know when to stop. Look around at metal farm building and see the dents from the inside from guys getting too close with the loader bucket.
   / Our Tractor was delivered today #67
I can't recall anything in the manual about that. It is poorly written IMHO, I got halfway through again today but chores called. I think I'm going to keep the box blade mounted, plus I have fluid in the tires, to use for added ballast until I get a ballast box. Wondering what you and others advise about this.
Box blade that is wider than width of tractor makes the best counter weight (loaded rear tires also). I have a Workmaster 50 and 8 ft box blade works great.
   / Our Tractor was delivered today #68
To my knowledge with the equipment I own…
There is no way to relieve the pressure With The Engine Running..
So if you are attempting to add to auxiliary circuits the pump is constantly supplying pressure.
Like mentioned before by others.
Move the valve particularly pertaining to the circuit you are trying to attach to.
You should hear or see the hydraulics settle or relax.
You have to be broad shouldered and corn fed stout to plug into a live circuit.
   / Our Tractor was delivered today #69
I "kissed" the corner of my pole barn with the bucket - twice. I was going slow, and being a hydro drive it didn't knock the building over. Just a big dent in the corner trim. I took the bucket off to mow after that. I use a ZT now, so the 855 is not used for mowing any more.
That's for the sage advice and input, sir!
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A53472)
2021 John Deere...
Wolverine BC-13-72W, 72" Skid Steer Brush Cutter (A52384)
Wolverine...
UNUSED INDUSTRIAS AMERICA L5 HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
