over running PTO clutch
   / over running PTO clutch #21
oh, i see. mine doesnt have a button, it has a sleeve that slides back
Well again I might be using the wrong terminology for this part :cool:
it is a button on the end of a small sleeve through a spring, the sleeve has a key-way in the side that once the button is press in will line up with the splines on the PTO enabling it to be pull off/on ........ are you messin with me:D
   / over running PTO clutch #22
nope. mine has a round sleve that goes around the entire thing. i somply slode the sleeve back and slip it on or off. no button. My shaft for the old snowblower had a button so i know what your talking about.
   / over running PTO clutch #23
yeah.... one would think grease would prevent them from getting stuck :cool:
although have been known too, just as a mower wheel & woodruff key gets stuck on the axle shaft of a ridding mower, I think because they're such a tight fit grease cannot get into the contact parts, and what little does winds up drying out to a crust and promote adhesion between the 2 parts;)
yep, for sure needs periodic lube. at least with a roll pin, it has a hollow center, and a split down the side for lube to seep in, unlike a darn woodruff key that once fit, is fit all around and when seized, is a real bugger! I don't mind drilling a thin hollow roll pin. digging out or drilling a galled / seized hardened moon or woodruff key is a horrible job :(
soundguy
   / over running PTO clutch #24
if it's a thin metal sleave, that one usually has a relieved groove inside that lets about 3 balls fall back for removal, I've seen some with a plastic collar and under that collar was a hidden button like the other poster mentioned, and twisting the collar pushed the button.. and yeah.. when they stick, they stick.
I had to take one apart the other day on a beater 5' mower I picked up.. slip ring off and parts out.. and some penetrant oil, and as the other poster mentioned.. tapping with a hammer back and forth.. etc.
soundguy
   / over running PTO clutch #25
you are good. there are at least a half dozen pto coupler styles, some with push buttones both external and some under a collar, some with a pull back collar, some with a push forward collar, some with a twist collar, some old ones that pin on. and some the a pinch pin that rides in a droove, and when pushed has a relief in it to slip on / off.
soundguy
Quick Attach Pallet Forks (A47384)
Quick Attach...
DIRTDOG CBX60 5' BOX BLADE (A51243)
DIRTDOG CBX60 5'...
Aluma 7712H Tilt Trailer (A50514)
Aluma 7712H Tilt...
Quick Attach...
2018 John Deere 1445 72in Front Mower (A48082)
2018 John Deere...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2017 Chevrolet...
