Overheated Briefly, Now Discolored Coolant... Flush Radiator?
   / Overheated Briefly, Now Discolored Coolant... Flush Radiator? #11
Personally, I think she came down extra hard on you... not sure why. If you are overheating, you should stop IMMEDIATELY... Seems to be a rash of over reacting forks on TBN :confused2:
Win some lose some, not my tractor. But I would bet good money that wasn't dust in the bottom of the surge tank. Hopefully everything will turn out ok for her.
   / Overheated Briefly, Now Discolored Coolant... Flush Radiator? #12
That's because the safety police are hiding in the bushes. :)
No place to hide around here, bushes get trimmed about 1/2" above the ground, and the safety police get shown where the doughnut shop is located.:thumbsup:
   / Overheated Briefly, Now Discolored Coolant... Flush Radiator? #13
When she cooked it, it loosen all the scale & rust in the block. Which made the coolant look dark. Then it settled out. Now that all the gunk has been loosen up is the time to drain and give the system a good flush. As for the oil, might still look okay, but how hot was it. Did the oil get hot enough to cause the additives to drop out? Oil and coolant is cheap, why take a chance.
Ummm "cooked it"? And "scale and rust"? With a high temp light that came on for 3 to 5 minutes (there's no guage on the 3038e, just a warning light) when I reduced the throttle and disengaged the PTO. The oil is still gold! If the additives "dropped out" wouldn't there be some indication? Separation on the stick, odd odor, something? Also, the tractor has 210 hours on it, 100 of which were put on in the last 2 months by me. It seems unlikely that it has that much scale and rust in the radiator. No decrease in the coolant volume since the top off, and no oil in it. Also, when coolant is heated, does it stay bright green, or does darken or change color?
Also, as for stopping immediately, do you really want to just shut down an over-hot engine? Wouldn't it do more damage that way? I was always taught to run them if you can until they were back in proper temp range before shutting down, once you've fixed the problem that's causing the overheat. Which is correct?
   / Overheated Briefly, Now Discolored Coolant... Flush Radiator? #15
Coolant only changes color when something is added to it to enact the change. It's not reversible, it the sense it's not one color when cold - then another when hot. If your coolant is not the same color as when it came out of the bottle, the color change was caused by some form of contamination. Drain/flush/refill should follow.
If you have a turbocharger - especially one that's not oil cooled - it's a good idea to let the engine idle briefly before shutting down. Turbos operate at much higher than engine temperature. When so equipped, it's the turbo that benefits from a cool-down period, not the engine. Other than the turbo, the internals are designed for efficiency and longevity based upon a specified operating temperature. Allowing them to move/mesh above that threshold does more harm than good. Since the 3038E is turbo-charged, it doesn't hurt to let an engine at normal operating temperature idle for a few moments before shutting down.
But your engine was operating above normal operating temperature, which is even harder on the turbo. It should have been shut down as soon as it indicated an overheat condition. That's why they installed a red light, and not a blue or pink or purple one. There are a number of causes for over-heating, some of which can make the problem worse at idle than at speed. All you had was a warning that an over-heat condition was present. But that was the extent of your understanding at the time.
My 3720 has a temp gauge rather than an idiot light, but it also has a very loud and annoying alarm for certain engine codes; one of them is over-heating. The only way to silence the alarm is to shut down the engine. So while your intentions were good, your science was wrong. In my book, the correct procedure would have been to shut down the engine - then find out and fix what caused the warning light to come on in the first place.
//greg//
   / Overheated Briefly, Now Discolored Coolant... Flush Radiator? #16
I'd be a little curious about this "drop out" comment too. It sounds more like a little of the buzz word vocabulary along with "blown tranny" and such. The additives are not some type of sand mixture or like Teflon in certain oil products. Additives can get depleted and oil can burn, but the oil is quite capable of taking elevated temperatures as long as it isn't exposed to direct flame or extreme temperatures. Oil lives in bearings and those temperatures easily run 100 degrees over coolant temperatures.
I don't have a lot of problem with your practice of shutting down when overheated (my emphasis on the if you can). My practice has always been to remove the load and reduce the rpm. See if you can find the cause of the problem within a very short time span. It's a catch 22 situation where sometimes immediate shutdown is best and sometimes a simple 30 second fix is best. In this case, it was a blocked cooling system that could have been addressed quickly without a shutdown.
AutoEducation.com - Motor Oil Breakdown, What really causes it?
I wander how hot the oil gets at the wrist pin & bushing ?
   / Overheated Briefly, Now Discolored Coolant... Flush Radiator? #17
If you know that your coolant is still up then yes you are correct to keep it running. Removing the load and letting it run at an elevated idle speed is best. On the other hand if loss of coolant is suspected then no amount of idling will cool the engine and shut down is the only option.
   / Overheated Briefly, Now Discolored Coolant... Flush Radiator? #18
But sitting on the seat of a 3038E, there's no way to determine the cause of the illuminated idiot light. Hence, shut it down without hesitation and determine the cause.
//greg//
   / Overheated Briefly, Now Discolored Coolant... Flush Radiator? #19
//greg//
Any operator worth his/her salt will know if the antifreeze has been lost. If it is a slow leak then the op should be keeping track, a major leak will be obvious, at least to an observant operator.:thumbsup:
   / Overheated Briefly, Now Discolored Coolant... Flush Radiator? #20
Different oils break down at different temps. Additives could cook up quicker possibly. Personally fluids are cheap (in comparison to parts and labor) , so when it doubt change it out.
If a crack head or head gasket happened on such a young tractor wth a mild over heating problem, then I would sell the POJ as soon as I could.
As for running it without a load was probably the best thing to do to it. I noticed when brush hogging that my temps would get up to about 160 and as soon as I would get rolling forward for a short way the temp would drop 30 degrees.
2008 JLG 800S TELESCOPIC MANLIFT (A52705)
2008 JLG 800S...
2011 Ford F-350 Knapheide Stakebody Flatbed Truck (A52377)
2011 Ford F-350...
2020 CHEVROLET SILVERADO TRUCK (A51406)
2020 CHEVROLET...
2013 Ford Transit Connect Van (A52377)
2013 Ford Transit...
JOHN DEERE 6135RW401 MOTOR (A51247)
JOHN DEERE...
48 Inch Grapple Root Bucket (A55218)
48 Inch Grapple...
