Overheated Robin EH72-FI (28 hp) in PT-425 solved
   / Overheated Robin EH72-FI (28 hp) in PT-425 solved #111
   / Overheated Robin EH72-FI (28 hp) in PT-425 solved #112
What kind of stress did you put on that motor shaft?
Your two options are .
Rebuild the motor with new shaft.
Replace with new motor.
   / Overheated Robin EH72-FI (28 hp) in PT-425 solved #113
Nothing out of the usual. I do run it on a lot of sloped/hillside areas(it sits now precariously on a hillside) and make turns on that would stress the shaft, but I thought the PT should be able to handle that. I'll probably be calling Terry to order a new motor and when I have time look at rebuilding the old one. Any resources/step by step instructions to rebuild would be appreciated.
   / Overheated Robin EH72-FI (28 hp) in PT-425 solved #114
Well, good news(sorta)....instead of buying a new pump Terry in Tazewell will put in a new shaft and rebuild for considerably less...just means more down time waiting for it to come back. He also suggest I get an impact wrench to get it back onto the shaft...said hand tightening the nut will not be good enough....I've been meaning to buy one anyhow.
   / Overheated Robin EH72-FI (28 hp) in PT-425 solved #115
Ouch! Sorry for your troubles. How many hours on the machine?
   / Overheated Robin EH72-FI (28 hp) in PT-425 solved #117
Finally got the Robin exhaust installed. I have several feet left over of the Walker flex pipe..so if anybody needs any.
   / Overheated Robin EH72-FI (28 hp) in PT-425 solved #118
I ran the 422 last night for 1.5 hours with the 48" grass cutter going at full throttle. I STRONGLY encourage anybody with the Robin engine and stock PT exhaust to consider replacing with the Robin exhaust. Sure it will cost ya a few bucks(mine was $190) and a bit of time fitting it to the PT but man, what a difference! As stated earlier in this thread, the tub temps are way down and I was pleasantly surprised that I also gained a few HP as was evident when mowing up some hills. Previously I would either have to back up some of my steeper hills or find another approach but now I can go right up the slopes except for my steepest one. I also am not getting the backfire at shut down either.
I really hope this has solved my hot temps issue, just wish I had done this many hours ago and may have saved me a rebuild last winter!
   / Overheated Robin EH72-FI (28 hp) in PT-425 solved #119
Congratulations!!! That is a wonderful.
I'm always impressed at how finely balanced air cooled gasoline engines are.
Thanks for sharing this.
All the best,
Peter
24" PIN ON BUCKET (A52707)
24" PIN ON BUCKET...
2002 Ford F-250 4x4 Crew Cab Pickup Truck (A55788)
2002 Ford F-250...
2019 MACK ANTHEM AN64T  TANDEM AXLE SLEEPER (A56138)
2019 MACK ANTHEM...
New Holland C185 (A47477)
New Holland C185...
2014 Peterbilt 337 IMT 10,000LB 5 Ton Crane Mechanics Service Truck (A55788)
2014 Peterbilt 337...
2012 Ram 1500 Crew Cab Pickup Truck (A53422)
2012 Ram 1500 Crew...
