Oxxn 8100 Install Summary - PTO Chipper - Long saga
/ Oxxn 8100 Install Summary - PTO Chipper - Long saga #1
RVThere
Pattenburg, NJ
JD 3520
After checking many posts here, I decided to order an Oxxn 8100 with the hydraulic feed. Let me tell you it pained me to buy something made in China but I needed a machine that could handle 8-inch Russian Olive that has overgrown a farm I bought back in February. A similar US build model would have been 4 times as much and that was out of the budget.
Oxxn had a fall cleanup sale where they knocked about $400 off the price if you ordered before Sept. 30 so I ordered a unit online on Saturday Sept. 29. They shipped it out that Monday and FedEx delivered it to my farm on Thursday (I could have had it Wednesday but I had meetings scheduled). I paid an extra $50 to have lift gate service.
The machine is shipped in an angle iron frame with plastic around it. It was in perfect condition with no scratches. They tell you to use your 3 point hitch to get it out of the frame but the vertical angle iron sides were in the way so I had to cut them out with a reciprocating saw.
The instructions are big on pictures and short on words. You definitely have to study the pictures, look for the right parts, compare back to the pictures, and use your best intuition. The hopper extension sides were cumbersome to install with one person so you may want to grab a helper. Complicating the assembly is that there seemed to be quite a few extra bolts, nuts and washers. Never a calm situation when you have a 225 lb disc spinning around and you're worried you forgot to install a critical bolt!
I assembled most of the machine Thursday night and bought the correct hydraulic fluid (7 gallons!) at NAPA. The PTO shaft seemed very tight to install so I called Oxxn on Friday with some questions. Vanessa answered the phone and was very cordial. She had her brother Chris call me back which he did so in less than 30 minutes. He told me to scrape some of the powder coat paint off the inside of the PTO shaft and grease it thoroughly. I also told him the hydraulic fluid was going in slowly due to the inlet filter on the tank. He said that providing I was using new fluid and my shop was relatively clean, I could remove that inlet filter so that the fluid went in quicker.
Got the fluid in Friday night and got the PTO shaft to slide on the chipper side. However, the shaft was too long. Following the instructions in the manual, I measured the distance between the locking rings and the total length of the shaft. Using the formula in the manual, I calculated that 4 inches needed to be cut off of both ends (26 inches - 23 inches) + 1 = 4 inches. Again using the reciprocating saw, I cut off 4 inches off of each end.
I slide the PTO shaft on one spindle and then when I go to slide it on the other spindle, it comes apart. The PTO shaft was now too short! As the side extension arms were all the way retracted, I could not make any adjustments to move the chipper closer to the tractor.
So Saturday morning I went to TSC and bought a PTO spindle extension as a stop gap measure. I installed the extension on the tractor side, adjusted the extension arms and tested the PTO with everyone a safe distance away. Ran fine in the shop with no load.
Took it outside the shop and ran a few big Russian olive clunkers through it and it chopped them up with no trouble at all. The hydraulic feed is really nice. Had to do some branch trimming because those trees tend to have a lot of branches at right angles.
Called Oxxn yesterday to tell them about my PTO shaft problems. Without a second thought, Vanessa said she would send out a new PTO shaft at no charge. (although I was the first customer to cut a PTO shaft too short...). I spoke to Chris again to explain my issue and he also said they would ship one out. Chris called me back today to say that a new shaft was being shipped. About an hour later I got an email from Fedex with a tracking number and it should be here by the weekend.
All in all, the chipper is a beast and Oxxn customer service has been superb! If your budget does not allow you to buy an American made chipper, this is definitely the way to go.
/ Oxxn 8100 Install Summary - PTO Chipper - Long saga #2
Pictures or YouTube vid?
Pics as requested.
PS - received new PTO shaft today!
/ Oxxn 8100 Install Summary - PTO Chipper - Long saga #4
I too have an OXXN chipper that I got about 2 months ago. It is awsome and the company has been just as nice and helpful to me as they were to you. Customer service is just as important as the machine is to me. Very happy with both the service and the machine. Well worth the money. Most of the wood I have chipped up was dry and seasoned. No problem for the chipper and green wood is even easier. Also my tractor is only 25 hp and does just fine. I think you will be happy with your purchase and congratulations on the new toy.:drink:
/ Oxxn 8100 Install Summary - PTO Chipper - Long saga #5
Just wanted to see how these chippers were doing now...Seriously considering the Oxxn brand and now they are using USA blades. Any updates would be appreciated and also how valuable is the hydraulic feed system? Just wanted to know if its worth the extra $500....
Chipper has been running well. Still on original set of blades. Only complaint would be when it clogs and jams you have to do some disassembly and digging with a long screwdriver to get all the chips out and free up the flywheel. But that could be because of the brush I am trying to chip.
The feed system is great. I don't know how effective it would be without the feed. I put in the pieces and walk away to get another piece. Makes the operation much more efficient.
/ Oxxn 8100 Install Summary - PTO Chipper - Long saga #7
My chipper is doing great, only clogged one time when I put a green evergreen tree in it. The whole tree. The load of pine needles couldn't clear fast enough. Of course I was running a 25 hp tractor too. I have the hydraulic feed system and think it is well worth the extra money. especially with my low hp tractor. If the tree is too big for the tractor and it starts to lug all I have to do is move the reverser bar and the tree backs out. I also put the side of the chipper into a tree and broke the housing for the reverse lever. I called Oxxn to order a replacement, they had it in stock, and sent it to me free of charge. I told them it was my fault and I was willing to pay but they didn't even charge me for the part. That is great service. I am very happy with my purchase and use it on a regular basis.
/ Oxxn 8100 Install Summary - PTO Chipper - Long saga #8
Help.
I have had an OX-8100 for 3-4 years, and use it on occasion. However, I hooked tried using it today and the belts are slipping to the point it will not turn the main shaft. I do not see an adjustment for belt tightness. And of course I cannot find the documentation for the chipper.
Does anyone have a remedy to this problem, or can someone supply me with the phone number for OXXN customer service.
thanks
/ Oxxn 8100 Install Summary - PTO Chipper - Long saga #9
I found this, no idea if it is any good.
Oxxn Inc
6204 Goodrich Rd, Clarence Center, NY 14032
(716) 406-2419
(855) 438-6996
/ Oxxn 8100 Install Summary - PTO Chipper - Long saga #10
Thanks for the information.
I'm not sure what the deal was with my chipper. Found that the main shaft would not turn counterclockwise - the direction the PTO turns it. However, I could turn it by hand clockwise. I open all the ports and looked for something jamming the chipper wheel, but could not find any thing. I messed with it for a couple of days and couldn't find any problems. However, last night went out and now the shaft turns both directions without any problem. I didn't do Anything with it!. ??? Oh well.
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
(2) TW 30 FORD WHEELS (A60432)
(2) TW 30 FORD...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
2015 Ford Fusion Sedan (A59231)
2015 Ford Fusion...
UNUSED X-STAR 250 GALLON FUEL TANK W/ FORK POCKETS (A60430)
UNUSED X-STAR 250...
UNUSED IRANCH HYD THUMB CLAMP (A60432)
UNUSED IRANCH HYD...
