oxy/acetylene filler metal?
   / oxy/acetylene filler metal? #11
I'll ditto coat hangers.
I tried using a coat hanger, but the melted plastic stunk & got all over everything /forums/images/graemlins/grin.gif (only kidding).
   / oxy/acetylene filler metal? #13
Same here on the coat hangers. I've never compared cost of rod versus coat hangers, but for the minimal amount of gas welding I do, coat hangers work great.
My neighbor is a certified welder and he uses coat hangers too. I had a metal hydraulic line for my blade bend in half by a tree on my dozer. I cut it and cleaned up the edges, but had him weld it back together. He used a coat hanger. I don't know the preasure that line handles, but it doesn't leak at all.
Eddie
   / oxy/acetylene filler metal? #14
Coat hangers when you run out of the copper coated rod and copper electrical wire when you run out of brazing rod. Don't remember the flux I used with the copper wire but it worked well in most cases. I once used gold rod when I gold flossed hydraulic lines when I worked for Southern Pacific when I was a kid.
Farwell
   / oxy/acetylene filler metal? #15
either rod you have there will work nicely. You never know what kind of cheap metal is in a coat hanger, you are better off with real filler metal that has been rated unless you are welding 2 coat hangers together, then I would use a coat hanger as a filler.
2014 Ford Escape (A50323)
2014 Ford Escape...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
2010 CHEVROLET SILVERADO 3500 (A52472)
2010 CHEVROLET...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2019 INTERNATIONAL...
2019 RAM CUTAWAY SERVICE BODY TRUCK (A52577)
2019 RAM CUTAWAY...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
