aczlan
Good Morning
- Joined
- Mar 7, 2008
- Messages
- 17,540
- Tractor
- Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
Try this site for it applies to a particular area:From the website - Under this regulation, it is illegal to burn wood, firelogs, pellets, or other solid fuels in your fireplace, woodstove, outdoor fire pit, or other wood-burning device on days for which the Air District issues a Winter Spare the Air Alert.
Ah, so on certain DAYS where air quality would be worsened due to particulates, unless:
(A) Residential or commercial properties where a wood -burning device is the sole source of heat; or
(B) A low income household; or
(C) Residential or commercial properties where there is no existing infrastructure for natural gas service within 150 feet of the property line; or
(D) Residential or commercial properties located 3,000 or more feet above mean sea level; or
(E) Ceremonial fires exempted under Rule 444 - Open Burning.
So, pretty much on certain days in urban areas when air quality is a problem because of the mass of humanity living there... Offer not valid if it's your only source of heat, you're low income, you don't have natural gas within 150 feet, you're above 3,000 feet elevation or you are hosting a Pagan celebration.
Or as the TBN Conservatives like to say "OMG, it's against the law to burn wood in California because libs, libs, LIBS!"
What was you saying again about strawmen?
So, if a woodstove is your sole source of heat, your MUST buy a multi thousand dollar EPA certified woodstove (and even if you buy a used one, IIRC it must be a catalytic model and installed by a "certified woodstove installer" (note that the catalyst will probbaly need to be replaced on a used stove to be "compliant"))http://www.baaqmd.gov/rules-and-compliance/wood-smoke said:Effective November 1, 2016 - Regulation 6, Rule 3, Section 110.1 requires anyone whose sole source of heat is a wood-burning device to utilize an EPA-certified or pellet-fueled device that is registered with the Air District for an exemption from the burn ban. An open hearth fireplace will no longer qualify for an exemption.
You must register your EPA-certified or pellet-fueled device with the Air District to be exempt from the burn ban alerts by November 1, 2016 or you are no longer exempt and subject to penalty for a violation.
And there is a ban for you...http://www.baaqmd.gov/rules-and-compliance/wood-smoke said:Effective November 1, 2016 - Bay Area residents who begin a chimney or fireplace remodeling project that costs over $15,000 and requires a building permit will only be allowed to install a gas-fueled, electric or EPA-certified device.
Effective November 1, 2016 - No wood-burning devices of any kind may be installed in new homes or buildings being constructed in the Bay Area.
You can "keep your current stove if you like it" but ONLY if it complies with the new rules...
There are members on here (Ultrarunner comes to mind) who live in the area, who have been required to remove or upgrade any wood stoves and who cannot give away seasoned split oak firewood.
So, yes its theoretically possible to legally burn wood, but its about a likely as the average person getting a concealed carry permit in NYC or Washington DC.
Aaron Z
