Painting my rusty junk?
   / Painting my rusty junk? #11
Faced with this choice I narrowed it down into two methods. For raelly good stuff that I'm going to take care of and store inside, I do as previously mentioned.
However, if iit's not going to be treated all that well, i found an easier way worth mention.
I sloppily wire brush any loose stuff for maybe 45 seconds. That's all. Then I get a stiff scrub brush and the wife's dishwashing detergent and scrub hard, rinse well and let dry. Prime with Rustoleum Rusty metal primer and then top coat with whatever. Actually, I prefer a better-quality acrylic enamel paint.
This approach sounds pretty shaky but has worked very well for me and I use it on most of my tillage equipment.
Just my two cents.
   / Painting my rusty junk? #12
that's not uncommon.. lotsa people power wash, spray with phosphoric acid to eat rust, then prime and paint.
soundguy
   / Painting my rusty junk? #13
Have you seen "Rust Removal with Washing Soda and Battery Charger"?....Sometime ago I did see some pics of a guy that did a whole utility trailer....of course he had to make some big bath arrangement with an old pool liner and some old concrete blocks......
Electrolytic Rust Removal aka Magic
I guess it only dissolves the rust and leaves the metal behind, which would be great for restoration work on antiques and collectables....
   / Painting my rusty junk? #14
Sandblasting is really pretty cheap, and by far the best. Saves incredible amounts of time amd elbow grease. I just did an old three bottom plow. They charged me $75 to blast and prime it. It looks too nice to use! I took mine apart and carried the pieces to them then reassembled it with new bolts. I would take off the gangs of discs and just let them do the main frame, then replace and broken discs and bearings and it will be like new.
   / Painting my rusty junk? #15
you'd need a huge tank to do big parts with electrolysys. works great on smaller stuff though.
soundguy
   / Painting my rusty junk? #16
soundguy
Get the biggest plastic garbage can and you are good to go.
Sandblasting does the best job but the Rustoleum Rust Reformer holds up well if you just knock off the loose rust. Be sure to leave a rust film on the part to get it to work correctly.
   / Painting my rusty junk? #17
I don't think that dual ganged disc is gonna fit a garbage can :) unless you meant garbage dumpster :) :)
I've used large kiddie pools .. works good.. get them at the beginning of winter when walmart clearances them for a couple bucks.. :)
soundguy
Thanks guys. I was thinking sandblasting before, and with the high cost of the converters and por, I think sandblasting will still be the best bet. Might only cost me a few extra dollars, but with better results.
   / Painting my rusty junk? #19
I wish I could convince others as to my post #11 above and how easy it is and how well it has worked for me. Over the years I have done the 100% perfect job and taken a lot of time to do it only to beat it in tillage work or upgrade to something else and have the new owner benefit from my efforts for little added cost.
Paint has never come off a clean, non-flaking rusty surface. The time saved gives me much more space for esoteric sfforts such as time with wife and dogs or perhaps pondering an occasional brew.
Attached is a photo of a spike harrow I made into 3-pt hitch and painted via the above method. It was a piece of rusty equipment I worked on and then painted.
It's not a Cadillac finish but for simple and easy looks surprisingly good. FYI.
   / Painting my rusty junk? #20
Electolysis process by far THE BEST!!!
I almost never pull my sandblaster out anymore for rust removal. The washing soda is incredibly cheap and the best thing is that it won't hurt the enviornment. So disposal is NO issue.
Get yourself some 2X12's and a tarp. Take the gangs off and the top link then put the whole thing in the tarp tank. A day or so with no work on your part and it's clean and ready for paint. The other benefit is that you actually put back the metal where the rust once was. Sand blasting takes the metal that has oxidized away. Not a huge issue but definitely better.
As for paint, there is no question here in my mind. I have used Hammerite for years and it is without a doubt THE BEST. No I have no association with them at all. Kilz has bought them out. They have two Hammerite products. Rust inhibitor and Rust encapsulator.
I use the Rust encapsulator on things like cultivator tines. It creates a rock hard finish and totally encapsulates any rust that may still be hanging around.
As you can tell I am a big fan of this.
Here in East Texas the heat and sun is brutal on paint finishes so that's why I use Hammerite. It cuts down drastically on the number of times I have to repaint.
Incidently, I first started using Hammerite about 40 years ago.:D
Glenn.
METAL TRAILER FRAME W/ AXLE (A52708)
METAL TRAILER...
Snow Dogg 7.5' Snow Plow w/Bracket (A55272)
Snow Dogg 7.5'...
2012 Toyota Camry Sedan (A56859)
2012 Toyota Camry...
MASSAGE CHAIR (A58214)
(2) CASE IH DRAWBARS (A52708)
(2) CASE IH...
SKID STEER ATTACHMENT TILLER (A58216)
SKID STEER...
