Pallet colony discovered in Washington field
   / Pallet colony discovered in Washington field #21
Can you get a motorized version of that ?? (in case of a mass attack)
   / Pallet colony discovered in Washington field #23
Oh no, another pallet thread, we are doomed.
   / Pallet colony discovered in Washington field #24
Theirs not to make reply,
Theirs not to reason why,
Theirs but to do and die:​
Regards,
A. Tennyson
So the pallets are in the Valley of Death ...
or
the pallets have created a Valley of Death?
Glad the march of the pallets is in a land far, far way...
Just say'n.
Later,
Dan
   / Pallet colony discovered in Washington field #25
Found one trying to sneak into the garage last night.
   / Pallet colony discovered in Washington field #26
To add a bit (just a tad) of seriousness, if trials were mentioned, the formation does look like a thrown-together make-shift canine agility course.
Ok, back to the fun. :)
   / Pallet colony discovered in Washington field #27
I'm taking no chances. There is a loaded pallet breaker always within reach.
Bruce
What a brilliant and simple concept for a tool! I could have used one of them when I busted up then re-assembled 6 pallets IOT make my hay-ring. As it was, I grunted around with a large pry-bar.
Anyway, Bruce (the OP), my heart is gladdened that you will take up the cause of determining this palletological phenomena. According to the previously posted 'Google Map' of the subject field, there will be:
Pallets to the right of you,
Pallets to the left of you,
Pallets in front of you
V-stack'd and number'd...*
Take heed, my friend
and godspeed.
*apologies to Alfred, Lord Tennyson
   / Pallet colony discovered in Washington field #29
Bruce
I need one of those. Seriously. Does someone make one, or is this a "one more thing I can't have 'cause I don't weld" item?
   / Pallet colony discovered in Washington field #30
and godspeed.
I thought it was:
Pallets to the left of me,
pallets to the right
Here I am
stuck in the middle with you.
2005 Kaufman Trailers Trailer, VIN # 15XFW53265L001140 (A53421)
2005 Kaufman...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
2020 KUBOTA RTV...
