Pallet forks and fork frame
   / Pallet forks and fork frame #1
vacman
Sheridan, Il.
2015 Kubota B2650 (2004 Kubota B2410 Sold)
I asked this question earlier but was specific to a Kubota frame so no one replied. Hopefully this will be a better method of asking.
Are forks made for a forklift built to a certain standard so they are interchangeable? I am looking at the Kubota B1659 frame but I'm not sure if I would have to buy kubota forks or not. I found many threads on here of people buying used forks from repair companies but it seems like they are mostly building a frame to go with them. I have access to some forks but don't know if they would work. I found one picture of this frame from a head on angle. It looks like the same style but I can't tell dimensions.
Anybody have any thoughts.
Thanks.
John
   / Pallet forks and fork frame #2
Thanks.
John
There are different classes of forks. There are class 1-5 that I know of. The difference between each is the fork itself is thicker and the distance between the the hooks were the fork latches on is different.
Page 7 has the different classes.
https://www.cascorp.com/web2/downloads.nsf/links/12_Cascade_Fork-Facts/$FILE/2012_ForkFacts.pdf
   / Pallet forks and fork frame #3
Some good info here: Technical Information
The general standard for the size used on tractors is class 2's that have 16" spacing
   / Pallet forks and fork frame #4
I too had a pair of old forks from an old fork truck at work. So I bought this:
New Skidsteer Pallet Fork Frame skid steer loader attachment kubota (FRLDNS)
They shipped right away. Free freight to a commercial address. Came Fedex ground. My forks slid on without a problem.
The distance between the "hooks" on my forks was 16 inches. I understand there are larger ones out there. But 16 inch is quite common. This frame handled 16 inch perfectly.
I only have a Kioti CK20 anyway, so I really can't lift all that much. I think the frame itself weighs about 160 lbs and my forks weigh 87 lbs each. This setup will lift I think 4000 lbs but my loader won't so I don't worry if this is strong enough.
Very good experience buying the frame.
Dennis
Thank you guys. That is exactly what I was looking for. I can measure the forks and then compare it to the frame.
John
   / Pallet forks and fork frame #6
I have a skid steer quick attach on my tractor. I bought regular skid steer QA forks at a local supplier for the same price as Titan forks on Ebay. Just over $500 incl tax. If your loader has the SSQA plate then it should be able to use any skid steer attachments. My forks are the class 2 type (16") shown in the link provided by Kennyd.
iDrive TDS-2010H...
Mower King Brush Cutter (A53317)
Mower King Brush...
2015 Ram 1500 Crew Cab Pickup Truck (A59230)
2015 Ram 1500 Crew...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere 5045E for sale Auction
John Deere 5045E...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
