Pallet forks suppose to be loose or SSQA bracket improperly made?
   / Pallet forks suppose to be loose or SSQA bracket improperly made?
I understand. I tend to avoid Harbor Freight or Walmart for a lot of stuff, but sometimes cheap semi-disposable stuff is a better answer than the more expensive options.
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #62
, the warranty has been voided because you modified it from factory specs.
Therein lies the problem. There were no factory specs they built it to. That is why we are talking.
My guess is these are Chinese and that is why they never have fixed the underlying issue of fabrication. They probably make $75 per unit and just call it a wash when they have a problem rather than try to fix the issue through a language/cultural barrier. If you look at the steel in one of those forks, you would have a hard time buying it for what they charge.
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #63
I bought a "Dirt Dog" brand front bale spike with qa and it fit just like the front bucket from the factory with no play when you tighten the levers. Quality piece.
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #64
I agree Tom. But it still aggravates me that we as a people are willing to sell out our standards to make a buck. There's no real excuse for this. I totally understand having something built in China if it increases profit margins. But that's no excuse to ignore standards. The Chinese, or any other nation including Mexico that's building products for us will only build them to whatever standards we enforce. If we reject anything below that standard, they will comply. If not, they will continue to make and sell us junk. It's simple human nature. We'd do it to them too.
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #65
Richard,
Remember the term "Japanese Junk"? That was thrown around in the '60's & 70's relating to Japanese manufactured equipment. I don't think anyone associates Japanese made equipment with "Junk" anymore, do you?
Remaining comment not directed at Richard...
I've heard that these fitment issues seem to be more of a Kubota SSQA problem as Kubota is slightly off on their standard compared to others. Anyone here have a different experience? Do you think a company like "WildKat", who by the way MAKES their equipment on-site, would stay in business long if ALL their products didn't fit skid-steer equipment right? As far as their company, it isn't a "China" issue at all. Btw, WildKat's shop is 40 miles from my house, I've been there multiple times.
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #66
You are exactly right. Since Titan has been doing this refund for years I have no other explanation for it. Price talks so they sell a lot. I bought one of their ssqa adapter plates to weld to an old bucket and it was spot on dimensionally. So they obviously know the correct dimensions.
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #67
I have a Wildkat that fits loosely and none of my 3 SSQA attachment ends are made by Kubota. The Wildkat fits loosely on each. To some extent I want a little slop if I am working in mud or ice and I have some buildup over time I can still get the pins down.
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #68
Interesting Tom. I wonder what template/standard measurement Wildkat is using then? I believe they work on Bobcats at their shop too so I'd have to believe there are no problems with hooking up to them. Anyhow, the price was right and now, after adding shims, they fit tight.
HP
Welded it up last night. Found out I was out of larger sized filler rod & had some shielding gas issues, but I got the job done... Barely. It held up to some abuse with a quick spade.
Don't laugh at the weld quality. Will finish it up when I get some bigger filler rod.
   / Pallet forks suppose to be loose or SSQA bracket improperly made? #70
hey, you "got-er-done"
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58214)
2019 LOAD TRAIL...
Utility Cart (A59228)
2014 Dodge Charger Passenger Car, VIN # 2C3CDXAT8EH223963 (A57453)
2014 Dodge Charger...
2004 AGCO Gleaner 3000 Corn Header (A56436)
2004 AGCO Gleaner...
2011 Ford F-450 Service Truck with Crane, VIN # 1FD0X4GYXBED03383 (A57453)
2011 Ford F-450...
DEUTZ MARATHON...
