Papa T
/ Papa T #1
Papa T
Jacksonville, Tx
Mid 70's UTB 445
I have a mid 70's UTB 445 tractor that came with a piece of land I bought 2 years ago. It has run very strong until this week when the gear shifter stuck in Neutral as I was shifting out of Reverse.
Any ideas on how I can get it unstuck???
Thanks!
/ Papa T #3
Welcome
I've never worked on a UTB, but ill bet this is what you need to do.
Unbolt the shiftier / cover plate from the transmission and realign the shiftier forks. You tried to shift to fast and cross fired the gears.
Good Luck
E/S
/ Papa T #4
Dad's mf 135 does that once in a while... shift too fast, (mostly 4th to rev when brush hogging in some weird position on a hill) one shift rail doesn't fully return to center before the end slips out and over to the next shift rail... the ol massy has a removable plug in just the right place to use a long screw driver to pop the offending shift rail back to neutral and all is well.
HOOPER 30' TRI-AXLE GOOSENECK TRAILER (A63291)
HOOPER 30'...
240 Massey Ferguson Tractor (A61165)
240 Massey...
2022 EZ-GO ELITE...
KING 18 SHANK 3 BAR CHISEL PLOW (A63291)
KING 18 SHANK 3...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A63688)
2023 New Holland...
Brent 420 Grain Cart (A63688)
Brent 420 Grain...
