Papa T
/ Papa T #1
Papa T
Jacksonville, Tx
Mid 70's UTB 445
I have a mid 70's UTB 445 tractor that came with a piece of land I bought 2 years ago. It has run very strong until this week when the gear shifter stuck in Neutral as I was shifting out of Reverse.
Any ideas on how I can get it unstuck???
Thanks!
/ Papa T #3
Welcome
I've never worked on a UTB, but ill bet this is what you need to do.
Unbolt the shiftier / cover plate from the transmission and realign the shiftier forks. You tried to shift to fast and cross fired the gears.
Good Luck
E/S
/ Papa T #4
Dad's mf 135 does that once in a while... shift too fast, (mostly 4th to rev when brush hogging in some weird position on a hill) one shift rail doesn't fully return to center before the end slips out and over to the next shift rail... the ol massy has a removable plug in just the right place to use a long screw driver to pop the offending shift rail back to neutral and all is well.
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
Katolight SED60FJJ4 75kVA Towable Diesel Generator (A61572)
Katolight...
1986 CATERPILLAR D4H HI-TRACK CRAWLER DOZER (A64279)
1986 CATERPILLAR...
2018 CATERPILLAR 573D FELLER BUNCHER (A62129)
2018 CATERPILLAR...
2017 Ram 5500 Bucket Truck (A63689)
2017 Ram 5500...
