Parking pawl/Collar shift transmissions
   / Parking pawl/Collar shift transmissions
I don't know. That's what I'm trying to find out.
If it's an "automobile" type park position, then the weight of the tractor and implements would be "on the transmission" if you were parked on any type of hill or incline. That can't be good. I wonder if these tractors also have a parking brake?
   / Parking pawl/Collar shift transmissions #12
No they don't have a parking brake.
   / Parking pawl/Collar shift transmissions #13
Yes these tractors have a parking pawl, much like a car if they have the "standard TSS or CST" tranny. In the last five years I have only seen two or three with problems. One had parked on a hill with a extreme amount of weight in a trailer and then couldn't shift out of park, so he forced it until the shifter failed. The other slammed it into park while still moving. I even did a DTAC search for problems and while there have been a few problems reported, I don't think they are as bad as your dealer is making them out to be. Maybe he has some other tractors he needs to sell before he has to pay on them? Instead of ordering you a new one?
The dealer didn't offer an alternative so I don't know about him not wanting to order in a new one. Apparently it WAS some type of problem and apparently they are addressing it What exactly is a DTAC search? And how it that you came across two with pawl problems. Not much info in your bio
   / Parking pawl/Collar shift transmissions #15
DTAC is dealer technical assistance, where dealers can search deere for help with problems and solutions.
I work for a Deere Golf & Turf Dealer.
   / Parking pawl/Collar shift transmissions #16
So these tractors have a park setting like on a car with an automatic transmission? Why would you want that on a tractor?
   / Parking pawl/Collar shift transmissions #17
It's used so you don't have to use a parking brake. It essentially locks the wheels on the tractor. If you've been around farming and the older tractors you know they are very prone to running away on their own and pretty dangerous. The parking brakes don't always work the best even on brand new tractors. With the park function on the tractors unless the whole tractor slides you are safe.
   / Parking pawl/Collar shift transmissions #18
Are we talking about running or shut down tractors?
Whatever happened to parking a gear vehicle in gear? (engine stopped of course)
I've always done that although I consider the design of some (most? all?) tractors that have wet clutches where hydraulic pressure is used to engage the clutch instead of springs to engage and hydraulic assist to release an unfortunate design if it prevents using the tranny to help out. Sure the brakes should be set but I figure doesn't hurt to have a little redundency.
Tim
   / Parking pawl/Collar shift transmissions #19
Running or shut down tractors. Putting a tractor in gear will not stop it most of the time. Even in first gear. It's not like a tranny in a vehicle.
   / Parking pawl/Collar shift transmissions #20
Yeah the older combines like some tractors have bad parking brakes and I usually have to use a piece of wood at work to stop them from rolling all over the place. I usually put my 990 or the 70 in gear and it stops it fine on a hill just as you would a car. I don't get why its not like a car. For the large ag tractors they have a park in the range shift so you don't have to worry about the parking brake going out just like the 5000 series.
2004 Lull 944E-42 Telescopic Forklift (A53117)
2004 Lull 944E-42...
CAT 279D (A50123)
CAT 279D (A50123)
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
Unused 2025 GIYI KH72 72in 4-Way Hydraulic Bucket Skid Steer Attachment (A51691)
Unused 2025 GIYI...
8' DISC HARROW (A51247)
8' DISC HARROW...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A51247)
2000 TRAILKING...
