Pat's Easy Change Pat's Easy Change + JD 260 disc mower
   / Pat's Easy Change + JD 260 disc mower #1
Kfbeal
South Texas
2005 JD 5103
I have a JD 5103 I use for shredding, discing, loader work, and hay cutting/raking. I have a JD 260 disc mower that I use for mowing that attaches to the 3-point. I'd like to get the Pat's Easy Change for my lift arms but curious how they would take the unbalanced load of that disc mower?
If you're not familiar with the mower, here's a link to a picture: http://www.tractorhouse.com/images/Tractor/fullsize/81767468.jpg
When the hydr. cylinder is extended it changes the center of gravity and I was concerned with the connection on the quick release.
Any comments?
   / Pat's Easy Change + JD 260 disc mower #2
I think it will work fine.
   / Pat's Easy Change + JD 260 disc mower #3
I have them and use the Frontier DM 1160 disc mower ... no problems.
Thanks for the comments. I've used quick-hitches on Cat 3 equipment but nothing that ever put a strain upward on the quick releases like this would.
That Frontier looks identical to the JD 260. This cutter is probably 20 years old. We purchased 2 from the JD dealer and have had great luck with them. Not near as big as the newer ones but gets the job done. We don't cover 100's of acres like we used to.
John Deere 853 20ft Corn Head (A56436)
John Deere 853...
2016 Ford F-250 Knapheide Service Truck (A56858)
2016 Ford F-250...
(12) Ten Hole Steel Rims (A57454)
(12) Ten Hole...
2018 Ford F-150 Pickup Truck, VIN # 1FTMF1C54JKF07230 (A57453)
2018 Ford F-150...
2023 Chevrolet 1500 Silverado Z71 Crew Cab Pick-Up Truck (A56858)
2023 Chevrolet...
2008 INTERNATIONAL MA025 FLATBED (A55745)
2008 INTERNATIONAL...
