Pat's Easy Change Pat's Easy Change System
   / Pat's Easy Change System #11
Re: Pat\'s Easy Change System
Hey there
Hooking up the the 3 point to implement doesn't seem to be a problem for me. It's that darn PTO shaft hook up to the PTO shaft to the implement. That darn hook up to tractor, just have hard time lining up. Get grease all over hands etc. That's the part I don't like. Is there an easy way to do that?
Cheers...Coffeeman
   / Pat's Easy Change System #12
Practice, patience - and gloves
//greg//
   / Pat's Easy Change System #13
I was afraid the answer was something like that.
   / Pat's Easy Change System #14
I had the same problem with my Rhino cutter PTO. I took a small file and filed a bevel on the teeth. It helped a lot. The tractor PTO shaft is hardened so you won't file it. A small grinder could help. Overall, a very slight bevel - 1/16" or so, helps you get the shaft started.
As far as quick hitch goes, my Speeco is tops. I plan to buy a second and put it on my FEL so I have a long boom pole.
25 DUAL AXLE GOOSENECK TRAILER (A55745)
25 DUAL AXLE...
Truck Metal Cargo Storage Box (A55787)
Truck Metal Cargo...
Adams 6 Ton Hydraulic Lime Spreader (A57024)
Adams 6 Ton...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
2019 Doosan LCV6W Towable LED Light Tower (A54811)
2019 Doosan LCV6W...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
