Pecan Tree Damage?
/ Pecan Tree Damage? #1
two_bit_score
Super Star Member
Texas - from the brush and pear to the piney woods
John Deere 110 TLB, Diamond C 19LPX GN trailer
Ok, TBN brain trust, I need some advice.
What does this to pecan trees and how can it be treated?
DCBA4A8D-6C40-4529-BA11-4843B2DB6A15.jpeg. 108E0DA8-A72F-4A95-9A93-38FA47645687.jpeg
Thanks!
Are you talking about the mildewy looking marks on the bark?
You’re right that they look cut. Looks like they were chewed by something. The mildew looking stuff on that one branch picture is dirt.
I haven’t seen any worms in the tree or webs.
/ Pecan Tree Damage? #6
So something actually chewed the branches off like that? I thought they were cut or snapped by you.
Never seen anything like that.
/ Pecan Tree Damage? #7
Looks like someone went around with a knife evenly, then snapped center.
Kids or someone messing with you?
Were they on ground like that? I can't see an insect or animal doing that.
/ Pecan Tree Damage? #10
BTW, I'm not a fountain of knowledge. I'm just curious by nature and enjoy looking stuff up to learn new things....
I found that by googling "small branches falling off pecan tree" and that was the first thing that came up.
Hopefully, that's your pest. :thumbsup:
/ Pecan Tree Damage? #12
Burn/dispose the pieces that fall as that is where the next year’s tree girders are at.
/ Pecan Tree Damage? #13
I have seen those, but did not know what they do. And I have seen twigs chewed off like that. Thanks for posting.
Here in South Texas, late January or early February is a good time to trim back pecan trees.
I definitely believe you solved the mystery! Thank you! That seems to be exactly what has been getting the branches. I’ve actually seen some fall from high up in the tree and immediately went over and picked them up.
I threw them in the trash. I’ve never seen insects like that around the yard or in the tree.
I thought the tree was pretty healthy but one article says they attack a dying section of a tree. Maybe the tree is diseased.
Thanks Again!!!
They have been going in the trash and picked up by the city with household garbage.
I would hate to lose this pecan tree although squirrels usually get the pecans before we ever do.
Do you know of a treatment to kill the beetles? Or is pruning all you can do?
I was as confounded as that also when I first started seeing the branches. I kind of ignored it for awhile but stared seeing more and more so that’s when I decided to call on the TBN brain trust!
/ Pecan Tree Damage? #18
I used to have that happen to hickory trees. They looked like that they’d been cut by one of those roll around pipe cutters.
That’s a good way of describing the damage. What happened to the trees you had the beetles in?
/ Pecan Tree Damage? #20
Nothing. They were mature trees and they didn’t cut that many limbs off.
Case Axial-Flow Combine Wheels NO RESERVE (A63118)
Case Axial-Flow...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
TEST YOUR BID BUTTON! (A63291)
TEST YOUR BID...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 CATERPILLAR 310 EXCAVATOR (A62129)
2022 CATERPILLAR...
