Pecan Tree Damage?
   / Pecan Tree Damage? #12
Burn/dispose the pieces that fall as that is where the next year’s tree girders are at.
   / Pecan Tree Damage? #13
I have seen those, but did not know what they do. And I have seen twigs chewed off like that. Thanks for posting.
Here in South Texas, late January or early February is a good time to trim back pecan trees.
I definitely believe you solved the mystery! Thank you! That seems to be exactly what has been getting the branches. I’ve actually seen some fall from high up in the tree and immediately went over and picked them up.
I threw them in the trash. I’ve never seen insects like that around the yard or in the tree.
I thought the tree was pretty healthy but one article says they attack a dying section of a tree. Maybe the tree is diseased.
Thanks Again!!!
They have been going in the trash and picked up by the city with household garbage.
I would hate to lose this pecan tree although squirrels usually get the pecans before we ever do.
Do you know of a treatment to kill the beetles? Or is pruning all you can do?
Looks like someone went around with a knife evenly, then snapped center.
Kids or someone messing with you?
Were they on ground like that? I can't see an insect or animal doing that.
I was as confounded as that also when I first started seeing the branches. I kind of ignored it for awhile but stared seeing more and more so that’s when I decided to call on the TBN brain trust!
   / Pecan Tree Damage? #18
I used to have that happen to hickory trees. They looked like that they’d been cut by one of those roll around pipe cutters.
That’s a good way of describing the damage. What happened to the trees you had the beetles in?
   / Pecan Tree Damage? #20
Nothing. They were mature trees and they didn’t cut that many limbs off.
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A55302)
John Deere 6105E...
1518 (A57192)
1518 (A57192)
1571 (A57192)
1571 (A57192)
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
2020 Autocar ACX Xpeditor T/A Front Loader Garbage Truck (A55852)
2020 Autocar ACX...
