Permanent Solution for Hydraulic Piping for FEL Grapple
   / Permanent Solution for Hydraulic Piping for FEL Grapple #1
Fxfymn
Fredericksburg, VA
Kubota L4060 HST, FEL; Kubota BX2660
As I said in a previous post I have been having a hard time keeping the hoses I use to operate my grapple from being pinched by the loader, so I was going to try to use steel piping similar to the factory set-up. When I was looking for pipe I found weld on clamps from Baileys for hydraulic hose, so I decided to give those a try.
The clamps are a very clever design that allows you to weld the base plate directly a flat surface without interfering with the bolt that closes the clamp around the hoses.
I use a rear remote to operate the grapple.
I had previously mounted quick couplers on the post that supports the loader valve by drilling two 3/4" holes in the post below the loader valve. This allows me to remove the loader without having to remove the hoses from under the tractor. I placed 45 degree fittings on these QC's so the hoses would turn up toward the loader arms.
I welded two clamps on the bottom of the loader arms to hold the hoses, added 90 degree els to the grapple cyliner and QC's, and than made a detachable mount for the QC's that I use to disconnect the grapple from the loader. Total cost: about $25.00 for the clamps and pipe fittings.
The clamps and mount work much better than zip tying the hoses to the loader lines and I no longer have to use bungees to try to keep the hoses from being pinched.
Deere 410L (A53317)
Deere 410L (A53317)
Mini Skid 48in Root Rake Grapple Attachment (A56436)
Mini Skid 48in...
Skidsteer Wheel Tracks (A59814)
Skidsteer Wheel...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
MACK T/A DUMP TRUCK (A60430)
MACK T/A DUMP...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
