Photo of Grapple Kit for little tractors
   / Photo of Grapple Kit for little tractors #1
Steve_Carver
Approved Advertiser
Dunn, North Carolina
200 + Kubota Tractors
   / Photo of Grapple Kit for little tractors #2
This type of attachment makes sense. Everytime I try to fill my bucket with dirt, I whish I had the fork. Just dig into a pile of dirt and close the fork and tip the bucket back and you have a bucket full of dirt. I reallymiss this attachment. You may ask why not just go buy one, my wife has other ideas on what to spent money one, darn.
Dan L
   / Photo of Grapple Kit for little tractors #3
Steve, How much $$$?
General range for KIT is $900.for small loader buckets and more for bigger buckets.
Then you'll have to allow for aux. control valve, hoses,fittings, install labor.
So, I'd guess you'd have $1400. approx by the time is installed.
We ( as well as all dealers) can work with you to do the complete installation or provide many tips and short cuts for ya.
This item is an item that many owners can do the installation themselves.
   / Photo of Grapple Kit for little tractors #5
Steve .... thanks for the info. What range of tractors will they fit? (... an L3710?)
too bad that common sense ain't
   / Photo of Grapple Kit for little tractors #6
All I have to do now is figure out how to get that mounted with my removable fork brackets in the way! /w3tcompact/icons/frown.gif
del
oldcarparts@mygarage
   / Photo of Grapple Kit for little tractors #8
I considered a similar unit before I bought my 3ph pallet forks, but the price I was given was quite a bit more. Seems like this type of unit should be useful and solve many problems as well as improve safety.
One think I'm not clear on is how much the grapple forks open. It might limit some uses of the loader if the forks don't open wide enough to clear the back of the bucket. However, even with such a limitation, I imagine many owners would find their operations much easier with the grapples than without.
You are right on target. The sides of the bucket limit the "length of the payload."
The option for longer payloads is to install the Grapple Kit on to a forklift attachment.
If you have both forks and bucket.. you could switch the kit back and forth
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A52748)
DeeZee Crossover...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2020 Peterbilt 520 T/A Cab and Chassis Truck (A51692)
2020 Peterbilt 520...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
