Picked up new (to me) blower, one small problem
   / Picked up new (to me) blower, one small problem #1
ctgoldwing
Platinum Member
Central Connecticut
L3800HST
Well today I roped my son into coming with me to pick up the Normand snowblower I bought on Craigslist. From the storage container it was in I really couldn't read the plate info but I could tell it looked in fine condition & had both a hydraulic chute & deflector. Picking it up was easy peasy - the owner had a neighbor operate her tractor with clip on bucket forks to load in onto a truck I borrowed from work. Once home we slid it onto the truck's lift gate & lowered it to the garage floor. I moved it easily with a small floor jack.
It turns out not to be an Econor model that i had initially assumed but rather an N60-220 :thumbsup: I am sure its all of 600 lbs if its an ounce. In the light it really is in good shape:
BUT here is my problem:
There must be some type of easy 3 pt hook up on their tractor. I can't remove the pin :mad:
It appears the some sort of hollow keeper was driven through and the head ground off. I tried driving it out but had 0 success. Then I tried drilling the keeper out with progressively larger drill bits. Other than breaking 2 bits I have very little to show for my efforts :(
Now the only things I can think to try are cutting through the pins with a sawzall (I really don't think I'll live long enoung to get through the hardened steel) or borrowing a cutting torch & cut through them.
Can anyone suggest an easier way to get them out?
   / Picked up new (to me) blower, one small problem #2
Sawzall w/ a bimetal blade would be my choice.
   / Picked up new (to me) blower, one small problem #3
It turns out not to be an Econor model that i had initially assumed but rather an E60-220 :thumbsup: I am sure it all of 600 lbs if its an ounce. In the light it really is in good shape:
That looks Like a CAT 2 bushing for an I-Match or similar setup. The small pin is a roll pin to hold the bushing on the pin. You should be able to knock the small roll-pin out with a drift or punch.
HTH,
Mike
Sorry, poor reading on my part. I would try soaking with some penetrating oil but you really should be
able to knock it out with a punch and BFH :)
   / Picked up new (to me) blower, one small problem #4
Normally those are "spring pins" usually 1/2". They are a split pin that is driven in with a hammer. You can take them out with a punch the same size as the pin or drill them out. Since that unit does not look like it's been left out in the weather they should drive out.
   / Picked up new (to me) blower, one small problem #5
You should be able to drive the round pins out but if you need to cut it why not use a cut off wheel in a angle grinder it will take some work but much easier than a sawzall.
Rob
   / Picked up new (to me) blower, one small problem #6
I agree. The pin should be able to be driven out. If not just cut the pins but try not to damage the special adapters. You may need them some day.
Chris
   / Picked up new (to me) blower, one small problem #7
All you need is Roll Pin Punch for that size spring pin and you wil avoid a lot broken fingers and black finger nails that have not been pierced with a hot needle to relieve the pressure under the fingernal nail bed.:thumbsup:
Split spring pins are used to keep pins in place and prevent their movement.
A spring pin punch, a punch holder, and a very very small hammer are all you need for this-no point in destroying the good pins the blower has on it all ready.
Is it possible she still has the quick attach and she might sell it?
   / Picked up new (to me) blower, one small problem #8
Nice looking machine! Is that a Befco unit. I ask because that is the same naming style they used on my tiller.
My vote is for the cut off wheel. Be done in 5 minutes.
Thanks for all the quick replies. I am going to run out to Home Depot right now & get a set of punches. The only flat end punch I have is really too small. Now that several posters have mentioned it I can see the split in the insert - I initially thought it was solid around with a hollow core. Your explaination makes much more sense.
I am pretty sure she is going to keep her tractor (a MF) as she has several more implements including a finish mower that I am pretty sure she is going to use.
I soaked the insert with penetrating oil, now off to HD.
Thanks all - you guys are great!
   / Picked up new (to me) blower, one small problem #10
Those spring pins can be real challenge to remove if they've been in there a while. I would have someone hold the other pin so it doesn't rotate while you BEAT on the spring pin.
Good luck.
Nice find.
Wedge
New Swict 60" Skidloader Bucket (A50774)
New Swict 60"...
2016 Nissan Altima 2.5 (A50324)
2016 Nissan Altima...
2013 KENWORTH (INOPERABLE)W9 SERIES (A50854)
2013 KENWORTH...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
2011 Nissan Titan SV 4x4 Crew Cab Pickup Truck (A50323)
2011 Nissan Titan...
2014 FREIGHTLINER CASCADIA DAY CAB (A51219)
2014 FREIGHTLINER...
