If you're like many (most ?) people who are confused on this matter, probably the first word you might want to clear up is this one:
com瀕erè‹—ial/kəˈmərSHəl/
adjective
concerned with or engaged in commerce.
to help you out. federal law says (can't speak for state level. i hope the links work)
Regulations Section | Federal Motor Carrier Safety Administration (i bolded the important word. section 383.5 definitions)
Commercial motor vehicle (CMV) means a motor vehicle or combination of motor vehicles used in
commerce to transport passengers or property if the motor vehicle
Commerce means (a) any trade, traffic or transportation within the jurisdiction of the United States between a place in a State and a place outside of such State, including a place outside of the United States and (b) trade, traffic, and transportation in the United States which affects any trade, traffic, and transportation described in paragraph (a) of this definition.
Your example would be 29,999 pounds which is over 26,001 therefore CDL required. But since the trailer is under 10,000 that would make it a class B CDL instead of CDL A.
no true. you can run over the 26001 combined vehicle weight (at least federally, can't speak for all states) IF the truck GVWR is under 26000 lbs AND the trailer GVWR is under 10000
Regulations Section | Federal Motor Carrier Safety Administration (section 383.91 Commercial motor vehicle groups)
(1) Combination vehicle (Group A)輸ny combination of vehicles with a gross combination weight rating (GCWR) of 11,794 kilograms or more (26,001 pounds or more) provided the GVWR of the vehicle(s) being towed is in excess of 4,536 kilograms (10,000 pounds).
(2) Heavy Straight Vehicle (Group B)輸ny single vehicle with a GVWR of 11,794 kilograms or more (26,001 pounds or more), or any such vehicle towing a vehicle not in excess of 4,536 kilograms (10,000 pounds) GVWR.
1 is class A license combined >26000 LBS where the trailer (towed vehicle) has a GVWR >10000 lbs
2 is class B license vehicle with a GVWR of >26000 LBS
OR a vehicle with a GVWR >26000 towing a trailer (towed vehicle) with a GVWR <10000 lbs
so the example used of a 20000 lb truck falls under the GVWR of 26000, used in 2 (class B) and the trailer falls under the GVWR of 10000, used in 2 (class B)
i used to think the way you do, but have been corrected
