Pictures of CK20 HST
   / Pictures of CK20 HST #21
After your clear of the backhoe just lower it to the floor using the stabilizers and the bucket before disconnecting the hoses.
Steve
   / Pictures of CK20 HST #22
</font><font color="blue" class="small">( 1. Is the hydrolic fluid used for both the trans and for the hydrolics on the tractor, same reseriour under seat accross from the dip stick?)</font>
When you're sitting on the tractor, the reddish colored OIL spout is for all the hydro fluid, yes.
This is the procedure in a nut shell. Lower the BH bucket and stabilizers and adjust to take the pressure off the pins that hold the BH on (2). Remove the two pins and move the tractor forward just enough to clear the mounts. Lower the backhoe to the ground with the stabilizers outstretched, then turn off the tractor. Move the BH controls and the loader controls around some to relieve all the pressure in the lines and disconnect the quick connects, and plug them to keep dirt out.
Remember to turn the lever on the power beyond, where the backhoe hoses come from, back to the 6:00 position. If you need help locating that, let me know. The tractor will not run properly and the loader won't work if you don't do this.
Send me a private message by clicking on my user name and then send user a private message if you need any help.
John
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
More info coming soon! (A50323)
More info coming...
2019 Dodge Challenger Passenger Car (A51694)
2019 Dodge...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
