Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #402
Rob660.
Did you add piece of metal back side of bucket for push plate support?
Have all most the same setup.
I don't use the chain,so if I need to scrape I tilt bucket while plowing.
   / Pictures of your snow weapons #403
Just finished the cab first snow with a heated cab, gives new meaning to the term "seat time":D
   / Pictures of your snow weapons #404
We had over a foot of snow in the past 3 days here in Ohio,so I had a chance to try out the snowblower.
YouTube - DSCF5688
   / Pictures of your snow weapons #406
Snow storm just barely missing us lately,sooo decided to hookup and double check points of interest before old man winter says howya doing.
   / Pictures of your snow weapons #407
They say "old man winter" will visit us in southern WI tonight with 10-11". That is up from 3" just a couple hours ago. If I have to put the chains on and add the wing tomorrow, so be it. I look forward to the seat time, before the 25-30 mph winds at below zero hit Sunday night. Brrrrr!
   / Pictures of your snow weapons #408
Beenthere.
Enjoy the therapy. :)
   / Pictures of your snow weapons #409
My old standby Case 446 and snow blade. I haven't moved any snow yet with the Kioti . It just started snowing around noon and we have a couple of inches on the ground now.
   / Pictures of your snow weapons #410
Here's mine a Mahindra 2615 chains front and rear. Mostly I use the rear blade that I modified by attaching an old section of water pipe, welding it to the skid shoes and attaching the little brackets to give it more support in the middle.
I used to use it on my old Ford 2n and did a pretty nice job of bending it at which point I bolted on the iron channel which I later welded. I then snapped the thing at the point were the blade pivots and had it rewelded and strengthened. The guy that did it welded it back with a slight twist and I had to cut out part of the blade to get it to spin again, I won't be using him again.
I live in the cascade mountains in northern California and we tend to get really wet snow. Every winter is different but when it snows we tend to get at least a 8" and usually more.
Case skid steer wheels and tires (A56436)
Case skid steer...
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2010 LAREDO 5TH WHEEL (A58214)
2010 LAREDO 5TH...
UNUSED MOWERKING PALLET FORKS (A58376)
UNUSED MOWERKING...
CFG Industry H15R Mini Excavator (A57149)
CFG Industry H15R...
