Pin Mystery... where's it go?
   / Pin Mystery... where's it go? #1
dholly
Platinum Member
Fingerlakes Region, Upstate NY
B7610HST
Pin Mystery... where\'s it go?
Help! This pin fell off my 7610, darned if I can find where? Be nice now... /forums/images/graemlins/blush.gif
   / Pin Mystery... where's it go? #2
Re: Pin Mystery... where\'s it go?
Thats definitely a johnson rod retaining pin.
   / Pin Mystery... where's it go? #3
Looks very much like the large pin that holds the drawbar in place. Very bottom back. /forums/images/graemlins/grin.gif
Kevin
   / Pin Mystery... where's it go? #4
Do you have foldable ROPS?
I'm not sure, but looks like the ones that hold in the bolt (on the ROPS hinge) on either side.
Then again, after looking at your picture a second time, I'm not sure if they are that big or not.
   / Pin Mystery... where's it go? #5
My question is, did it take a round with your mower to find it? ZING! /forums/images/graemlins/shocked.gif /forums/images/graemlins/cool.gif
   / Pin Mystery... where's it go? #6
How about the bungee type strap that secures your lower links when nothing is attached.
   / Pin Mystery... where's it go? #7
Huh! None of the pins on my bota have that extra little curved part on them, seems like it would get in the way where a lot of these go.
Are you sure you just didn't find it laying there and it's off of something else.
   / Pin Mystery... where's it go? #8
Aaaahhhh
Eventually, something'll fall off.
Then you'll know. /forums/images/graemlins/smile.gif
   / Pin Mystery... where's it go? #9
Like Knight 9 said, it looks like the pin that secures the bolt/pin for the drawbar. My b2410 had the same retaining pin as well as my father's L3710. This pin can be dislodged in thick or high brush. Usually I would keep my darwbar off when not in use so as not to lose the pin or have it bent by backing into something.
   / Pin Mystery... where's it go? #10
I second...errr third the drawbar answer. The one on my B7610 looks just like it. Jeff
2016 Freightliner M2 106 Ambulance (A53422)
2016 Freightliner...
Miller Spectrum 500 DC Plasma Cutting System (A54811)
Miller Spectrum...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
2022 Kubota KX71-3S Mini Excavator (A52377)
2022 Kubota...
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
2020 Brenner 450 Gallon Skid Mounted Vacuum Tank (A52377)
2020 Brenner 450...
