Pine needle rake(everything attachments)?
/ Pine needle rake(everything attachments)? #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
Has anyone bought the pine needle 3 pt. rake(5 ft. yellow one) from everything attachments?If so how do you like it?I am thinking about purchasing the 5 ft. model in the near future.Thanks for any information.coobie
Somebody here has one and I am sure they will be along to tell you about it? IIRC they liked it.
Thanks glen.I want one for dethatching the lawn and leaf clean up.coobie
/ Pine needle rake(everything attachments)? #5
coobie,
I have the older Leinbach model with welded tines, I like the idea of replaceable tines and will purchase one of these when I need a new one. Heres some pics of my 6' rake and x749, does a good job imo.
To make a more agressive pass I hang two 42# weights around the top link post for mild dethatching.
coobie,
Great pics,you sold me now.I want to use the rake behind my JD X748 for spring dethatching and fall clean up for some of my leaves and pine needles.
/ Pine needle rake(everything attachments)? #7
coobie,
The PSR doea a great job with the needles but a fair job with small leaves. Lots of small leaves will pass through it. The tines are on 2" spacings, so as you can imagine lots of small leaves will be left behind. After raking an area with leaves and loosening them up I often use my Stilhl backpack blower to clear the leaves out.
coobie,
Steve,thanks for the info and pics.My lovely wife ordered the 5 ft. rake today from everything attachments.Early Xmas gift.LOL,coobie.
/ Pine needle rake(everything attachments)? #9
coobie,
I have have the same issue, does NOT work well for leaves. I also use a Stihl backpack for cleanup. I think the rake is to aggressive for dethatching use.
I am going to sell mine on Craigslist in the spring I think.
/ Pine needle rake(everything attachments)? #10
About the rake being too aggresive for dethatching I found the opposite to be true, but that is likely because the 3ph weight on my garden tractor is very light compared to the hitch on a larger tractor. You can shorten the top link to change the angle of the tines too.
The pine needle rake arrived today.I seems well constructed & arrived in a short time.Very happy with everthing attachments service and product.I will assemble the rake when time permits and post some pics.coobie
2001 Ford F-250 Reading Service Truck (A66736)
2001 Ford F-250...
2012 PETERBILT 388 (A67714)
2012 PETERBILT 388...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
15-19.5 Tire and Wheel (A68134)
15-19.5 Tire and...
2003 30ft Rinker Captiva Boat w 2017 30ft Tri-Axle HMDE Boat Trailer (A66738)
2003 30ft Rinker...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
