Pipe plowing with poly (roll) roll pipe vs. pipe pulling with PVC pipe
   / Pipe plowing with poly (roll) roll pipe vs. pipe pulling with PVC pipe
flusher said:
Question: have you ever pulled PVC pipe that had tees and risers inserted in the line for sprinkler heads? Just wondering if this is possible without shearing off the risers when pulling the pipe into the trench.
The other option is to pull the PVC pipe the standard way with unions connecting the sections and, once the line is in the trench, to use saddle tees to connect the risers. Problem here is possible leaks in these joints.
No I haven't and I'm sure it wouldn't work with tees attached. You will have to dig up the tee locations and install them. You can use regular tees because small pipe is flexible enough to work the tees in, and in short runs you can slide the pipe back and forth in the dirt by hand.
gabby
   / Pipe plowing with poly (roll) roll pipe vs. pipe pulling with PVC pipe #12
Interesting discussion. It encourages me to try PVC one of these days. I have pulled lots of poly (roll) pipe...but only 20 ft lengths or so... to take an electric fence charger wire under gates using a subsoiler.
I would add that I learned to do everything related to a pipe segment in one day. Once I pulled half way, got stopped and didn't get back for a week. If done immediately, the pipe slides easily back and forth in the subsoiler trench. However, waiting a while allows the soil to grip the pipe.... I pulled the pipe in two when I sought to contnue pulling the pipe and had to start over.
   / Pipe plowing with poly (roll) roll pipe vs. pipe pulling with PVC pipe #13
Gabby: I bought the subsoiler at TSC today while they had an in store discount on tillage equipment. The first thing I noticed when I got it home is that it is not I-Match compatable...probably with a little work it could become compatable.
I think I'll research the underground sprinkler sites for additional info on just what I'm going to need to buy and then have a go at it. Poly or PVC is still a question that need more research.
Thanks!
Jon
The only tme I pulled PVC apart was pulling 2" pipe. At 480 feet it broke just behind the puller.
gabby
   / Pipe plowing with poly (roll) roll pipe vs. pipe pulling with PVC pipe #15
My boo-boo was with poly pipe which had set in the ground for 1 week and gotten rained on... clay soil clamped down on it and wouldn't let go... have pulled lots at one time and it never froze up... but about 25 ft is longest poly pull I have done.
   / Pipe plowing with poly (roll) roll pipe vs. pipe pulling with PVC pipe #16
I am a plumbing contractor. I have had experience with poly pipe splitting. I have just finished a class on PEX pipe. I learned that the black poly pipe has a weakness. It is made with carbon chains that run length wise in the pipe. The PEX is cross linked for several reasons, but it resists the length wise splitting. Dragging poly through rocky soil could speed up the length wise splits. I am passing this on just to help in your efforts.
   / Pipe plowing with poly (roll) roll pipe vs. pipe pulling with PVC pipe #17
Thanks Gabby,
The information and picture were very helpful. I am going to install
400 feet schedule 40 1/2 inch pvc pipe according to your instructions.
   / Pipe plowing with poly (roll) roll pipe vs. pipe pulling with PVC pipe #18
I pulled in most of my irrigation system. 1" and 1 1/2" PVC. In some areas I pulled as much as 200 feet WITH tees installed. I'm sure I could have pulled farther but that was all I needed. Make sure you put the pipe together, then lay it on the ground where it's going. Carefully, mark on the ground, the end your pulling to, and the location of each tee . If you skip that step, you'll get a real work out with the shovel trying to find them. I wouldn't try it with the risers.
   / Pipe plowing with poly (roll) roll pipe vs. pipe pulling with PVC pipe #19
gabby
I know about PVC pipe for water lines but I am completely ignorant on roll
poly.
I have a camp I bought and I am renovating it. I think the water line that runs from the well to other end of the cabin is what you guys call roll poly.
It is black thin wall tubing either 1 inch or 1 1/2 inch in diameter.
It actually ran to an old trailer and is not in use at this time.
I have been trying to decide whether I should use it to supply water to my
cabin or replace it with PVC.
From the well to the start of the cabin is 40 feet . THen it runs underneath the cabin another 40 feet. So about 80 feet in total. The portion underneath the cabin is in a shallow trench not even covered with dirt but I could easily throw some dirt on it. The portion from the well to the cabin appears to be buired well and because of pine trees and other obstacles I would have to dig by hand and make some bends in the water line before I could reach the start of the cabin.
So here are my questions
1. Is this probably roll poly ? Is water supplied through roll poly - potable water ?
2. My camp is in lower southwest Mississippi so we do get some freezing in winter but basically pretty mild winters. Would covering it with 4 or 5 inches of soil be enough to keep it from breaking during the winter ?
Really appreciate any and all comments or suggestions. It certainly would be alot easier on me to hook back into the existing tubing and cover it with dirt.
However , I do want to do it right and do not want to supply non potable water to the cabin or have a problem every winter with this stuff breaking.
Thanks for your help
   / Pipe plowing with poly (roll) roll pipe vs. pipe pulling with PVC pipe #20
poly.
We have it running 200 feet from our well to cabin.
Buried about 6 to 8 inches. It has been there for at least 35 years and we drink from it. We only have about 2 freezes per year on average. Sometimes we drain it sometimes we don,t. If I was to replace it, I would go to PVC.
2017 John Deere 6120E (A53317)
2017 John Deere...
TANK MANIFOLD (A58216)
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
Landhonor Skidsteer Portable Screener (A59814)
Landhonor...
