Piranha bar or tooth bar
   / Piranha bar or tooth bar #1
Big Chief
stratford,CT
mahindra emax22 loader, backhoe
I am trying to decide which one a piranha bar or Titan tooth bar. I will weld the Titan setup my self. Just not sure which one. The piranha looks small and the Titan teeth look BIG, but I like big....and I work my stuff hard
I have seen all the posts on the piranha who has a tooth bar?
Going on a Mahindra Emax 50inch bucket.
   / Piranha bar or tooth bar #3
I have the Piranha bar. Works really well for my application. It will dig but it helps if the ground is not real dry. Plus I am able to back drag with it and still get a smooth run. Since we live in a National Forest it is great for keeping the underbrush clear. It will also take out small saplings with the way the teeth and designed. Just remember that FEL are not made for abuse when digging ! To easy to twist the frame or damage a cylinder.
So I decided on the titan tooth bar so I can use my pallet forks and bucket forks for my plow.
I will be welding it up tomorrow. Here are a few pics of the mock up.
   / Piranha bar or tooth bar #6
Looking good. Those are some serious teeth.
   / Piranha bar or tooth bar #7
I bought 8 Titan teeth, and then a piece of 1/2" x 3" flat stock.
I made my bar so that with shims, I can use it with either of my buckets.
Easy to swap, and works great.
All finished not bad for a amateur....
   / Piranha bar or tooth bar #9
Thats a very cool and great looking job !! Now go dig up the ground !
   / Piranha bar or tooth bar #10
Looks like the Manindra's been to the dentist and she's ready to eat.
2012 GALLEGOS 130 BBL STEEL VACUUM TRAILER (A55745)
2012 GALLEGOS 130...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
1996 International Water Truck with a Caterpillar Engine (A55315)
1996 International...
2023 ALLMAND 15XR MAXI-POWER GENERATOR (A52706)
2023 ALLMAND 15XR...
(4) 2017 Ford F150 Wheels and Tires (A54865)
(4) 2017 Ford F150...
2018 DRAGON 150 BBL ALUMINUM TRAILER (A55745)
2018 DRAGON 150...
