PJ Quick tilt Trailer
   / PJ Quick tilt Trailer
   / PJ Quick tilt Trailer #12
Wolf, what holds the forks in? Are the fork pockets on both sides? Sorry to hijack.
Matt:)
   / PJ Quick tilt Trailer #14
How much did you spend and what was the specifications of the model you bought?
The trailer is a 14K GVWR. It's 18.5' tilt + 4' fixed. I spec'd Dexter easy-lube axles and added the spare tire, 10K drop leg jack, LED lights, 16 5K D-Rings, and the fork pockets.
Cost = $7K
Matt:)
I chain the forks to D-Rings or Stake Pockets. You can see it in looped through the forks in the attached pictures in the original thread.
Do you use yours in the snow and if you do how is it to load a tractor on a tilt bed?
I plan to keep this trailer until I no longer am able or need to use it, so I avoid towing it in the winter. The amount of salt they use here in metro Detroit tends to eat anything metal.
The trailer is a wood deck and I have loaded in heavy rain without any issue. I typically have the tractor in 4WD when I am loading to prevent any surprises which I am sure helps. The rear 2 ft is diamond plate which is slick as ice when it is wet.
   / PJ Quick tilt Trailer #15
Cost = $7K
Ok thanks
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
1995 GMC CHIPPER/BUCKET TRUCK (A53426)
1995 GMC...
Brand New 5 gallon buckets (A53117)
Brand New 5 gallon...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
FRONTIER LR5060 LOT IDENTIFIER 97 (A53084)
FRONTIER LR5060...
