Plastic drum OK for diesel?
   / Plastic drum OK for diesel? #22
So then it will only cost me about $40 in gas for those "free" plastics barrels! /w3tcompact/icons/wink.gif
Thanks anyway!
   / Plastic drum OK for diesel? #23
Bill, here is a pic of my plastic fuel drum. I got rid of the steel 55 gal. drum since I am using less fuel now. I got the 30 gal. blue plastic drum from the city. It had contained sand flush, thats a soapy like stuff that they pour into storm drains, it makes the sand fluffy so the can flush it out of the drains. I have it on a $69.00 carry-all ftom TSC.Also got the pump for about $20.00 at TSC. My bulk dealer gave me the nozzel and hose. I only live one mile from the bulk plant so I just road the tractor over and fill up the drum. the drum is rounded on the bottom so it is easy to tip over and set off on the ground under the shed.
jim
   / Plastic drum OK for diesel? #25
Same here. The 5 gal cans are awkward to fill with, and I can often go through 5+ gals over a weekend. My tractor lives at a second home so I found I was dragging fuel cans back end forth every time I went to the house.
I got a 30 gal drum and pump and am very pleased with the results. Filling the tractor is much easier, and I only need to get the drum filled every 1-3 months depending on what I'm doing. I first starting using the drum last winter and I think I've filled it three times so far.
   / Plastic drum OK for diesel? #26
Where'd you get the 30 gallon drum?
   / Plastic drum OK for diesel? #27
I got it from a drum manufacturer in Lowell, MA. It was local and available. Unfortunately I don't recall the name of the place, but I found them via the yellow pages. I suspect most metropolitan areas have one or more suppliers.
   / Plastic drum OK for diesel? #28
Mike,
I have 30 gallons for diesel storage but I did it with two 15 gallon plastic barrels that I bought from G.I. Joe's. They are intended for water (blue) but the are sturdy enough for fuel. Sportco also has them. They have the fine and coarse thread bungs and the Harbor Frieght barrel pump ($20) works just fine. They are not so heavy that they can't be moved by hand.
Al
2004 IH 5600l Snow Plow Truck (A52384)
2004 IH 5600l Snow...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2011 Ford Crown Victoria Passenger Car (A51694)
2011 Ford Crown...
2017 Club Car Carryall 300 Utility Cart (A51691)
2017 Club Car...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A52748)
2022 Gravely...
