please help me choose between 2 TSC rotary cutters.
   / please help me choose between 2 TSC rotary cutters. #11
Tractor is a Ford 1520 4wd 23hp / 19.5 at PTO so I am thinking 5 ft would be to much.
The upgrade to replace PTO shaft that was stolen included a shaft/clutch combination.
The id tag on old stock gear box has weathered and numbers and mfg are not readable.
But the older gearbox looks larger.
Thanks for the advice.
Johnny Walker
The engine HP and the PTO HP noted here are about the same as the 8N. I have been using a 5 ft KK 3 pt. brush hog for about 19 years now. I even had a custom brush hogging business on the side using them.. Other than needing to use an ORC, I have never really had any problems using the 5 ft unit. The 1520 should not have any either..
   / please help me choose between 2 TSC rotary cutters. #12
I've had good luck with my 6' King Kutter brush mower. I like it, its a far better cutter than my previous 5' John Deere 513 was.
   / please help me choose between 2 TSC rotary cutters. #13
I would also recommend the 5ft cutter. Your 1520 will handle it nicely.
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
159118 (A60430)
159118 (A60430)
2020 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A60429)
2020 CATERPILLAR...
John Deere 1025R (A53317)
John Deere 1025R...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A56438)
2014 Doyle Dry...
