Please help me repair this
   / Please help me repair this #21
I think everyone is overthinking the problem. Its not so much that the design is wrong, although it could have put better use of structural steel rather than pipe, but the problem is just the CRAPPY weld. I am surprised that it didnt fall off in transit with that weld. Welding the wedge to the pipe is not that hard. Grind off all the old weld, place it back in the original position and put several passes of 7018 on each side and it will then hold as much as the pipe will stand.
   / Please help me repair this #22
Have to agree with Gary , I don't see the problem just a little grinding and 6 or 8 7018s and you back in business, why make a easy fix difficult?
   / Please help me repair this #23
When I first read the OPs post,. I thought, I auta offer to take the POS of his hands. Dont look that bad to me,
If you know how to grind prep and weld, Your in businsess. I wouldnt design and build one like that, But I think it will split wood just fine.
kubotakid USA
   / Please help me repair this #24
That second bottle jack splitter would make a good bench press with a little redesigning, some material and a bit of labour. It will never make a labour saving wood splitter.......
   / Please help me repair this #25
I agree, and thanks for supporting my point- it really is a sturdy little splitter.
I just thought I'd suggest an easier method of reinforcement, since that seemed to be the consensus.
Thomas
Thanks again for all the help. I suppose I'll weld the bottom of the wedge to a 2" receiver tube(1/4 thick), then stick it up from below-between the tubes, and weld to the tubes. The receiver will give me a good way to both brace it and tow it around.
I don't know if my 110 V Miller wire feed is up to the task of the thick wedge. I may have to take it out to a pro...
   / Please help me repair this #27
I have the 3 point version.
This ad is from 1982.
2016 GMC Sierra Pickup Truck, VIN # 1GTN1LEC5GZ901362 (A51572)
2016 GMC Sierra...
2021 ONYX RX34 ELECTRIC SWEEPER (A51406)
2021 ONYX RX34...
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
Approximately 250 Traffic Cones (A51573)
Approximately 250...
Wolverine BC-13-72W, 72" Skid Steer Brush Cutter (A52384)
Wolverine...
