PLOW INFO
/ PLOW INFO #1
JUBILEE1953
Ohio
MF 1742 TLB - Ford NAA
Can someone tell if a Dearborn 2 bottom plow is a good plow? My friend tells me its in mint condition. I'm not sure what mint means when refering to a used plow. Any imput about average selling price?
/ PLOW INFO #2
Dearborns were good plows. A picture would be nice to confirm what model it is. If it what I expect it is, I would say a value of $200 to $350 if it's in good shape. However, it depends on what you plan to use it for and what you are pulling it with. The Dearborns I have seen without trip protection (in my opinion) should not be pulled by anything bigger than 30 or 35 HP, and care must be taken not to snag a large rock or root, or the plow can be damaged. Personally, I would not a get a plow without trip protection, regardless of cost. I am not sure if any Dearborns were made with trip protection. Most I have seen did not have that feature. I bent the frame of mine the first time I used it.
/ PLOW INFO
I dont have a picture at the moment, its a Dearborn Series 10-1 two bottom plow, if thats any help.
/ PLOW INFO #4
If it is a 2 piece setup dearborn, wear parts are impossible to fine. A 3 piece has parts availability. Ken Sweet
/ PLOW INFO #5
I had one of these plows that had the three peice bottoms. (parts are available for them) I sold mine which was mint....and had the coulters and rolling landside (rear wheel) for $475. Good little plows like this are getting harder to find and will bring a good price.....but lots of worn ones are out there too.
/ PLOW INFO #6
Here is a picture of a 3 piece setup. Ken Sweet
/ PLOW INFO #8
Price is very much dependent on location. Any plow that's still useable is going to sell for at least $150 and even then it will be bought by someone who will clean it up, paint it, and then asked $350 or more. The last 2 bottom Dearborn I saw in CL locally was over $450, it was in great shape and included an extra new point. Not sure if it was a 2 piece or 3 piece though. I know it didn't have trip protection so I didn't even look at it as I have lots of rocks, ledge, and roots. What type of land will you be using it on? Are there lots of things you could get caught on?
WACKER NEUSON  LTN8 LIGHT PLANT (A68842)
WACKER NEUSON...
PILES OF TARPS (DIMENSIONS UNKNOWN) (A68842)
PILES OF TARPS...
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2006 INTERNATIONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNATIONAL...
