Snow Attachments Plowing snow with rear blade
   / Plowing snow with rear blade
I'm going to adjust the 'bit' of the blade as you were saying Stonehaller. I adjusted it in the other direction landscaping last spring.
   / Plowing snow with rear blade #12
You can push, but you risk bending a swing arm designed more for tension than compression. (Yeah, I push sometimes...)
Can you rotate the blad 180 degrees and pull it with the convex side facing forward? This technique has been discussed in other threads.
   / Plowing snow with rear blade #14
I have a 7ft woods blade (RB84 I think) - I have been using skid shoes to keep the blade about 3/4"-1" above my gravel drive and pull forward. This has worked well including the 18" snowfall with the december blizzard. I angle the blade to the side and also change the bite with the top link as suggested. I tried the PVC pipe trick also and shattered a piece the first time out - too brittle in real cold weather. Some people have suggested using ABS as it is less brittle, but I couldn't find a short piece at the big box stores. My blade does also reverse so you can pull it forward with the convex side forward to also limit digging into the gravel.
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
2013 Audi A6 AWD Sedan (A53424)
2013 Audi A6 AWD...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A55851)
2019 Caterpillar...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A55852)
2015 Freightliner...
2007 Deere 650J LGP (A53314)
2007 Deere 650J...
2007 FORD F-150 XL TRITON (A55745)
2007 FORD F-150 XL...
