Snow Attachments Plowing snow with rear blade
   / Plowing snow with rear blade
I'm going to adjust the 'bit' of the blade as you were saying Stonehaller. I adjusted it in the other direction landscaping last spring.
   / Plowing snow with rear blade #12
You can push, but you risk bending a swing arm designed more for tension than compression. (Yeah, I push sometimes...)
Can you rotate the blad 180 degrees and pull it with the convex side facing forward? This technique has been discussed in other threads.
   / Plowing snow with rear blade #14
I have a 7ft woods blade (RB84 I think) - I have been using skid shoes to keep the blade about 3/4"-1" above my gravel drive and pull forward. This has worked well including the 18" snowfall with the december blizzard. I angle the blade to the side and also change the bite with the top link as suggested. I tried the PVC pipe trick also and shattered a piece the first time out - too brittle in real cold weather. Some people have suggested using ABS as it is less brittle, but I couldn't find a short piece at the big box stores. My blade does also reverse so you can pull it forward with the convex side forward to also limit digging into the gravel.
2013 PETERBILT 367 TRI-DRIVE WET KIT (A55745)
2013 PETERBILT 367...
2025 78in Rock Bucket Skid Steer Attachment (A53421)
2025 78in Rock...
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
2012 Travis Body & Trailer Trailer, VIN # 48X9R5323C1007837 (A54865)
2012 Travis Body &...
2019 CHEVROLET SILVERADO LD CREW CAB TRUCK (A52706)
2019 CHEVROLET...
