Plugged hydraulic intake screen jd5055e
   / Plugged hydraulic intake screen jd5055e #11
magnet test is a good idea. looks like a bunch of dirt and dust to me. check your shifter boots and filler opening
   / Plugged hydraulic intake screen jd5055e #12
I’ll try that. The dealership said that they would look at it for me.
I'd be tempted to send a sample off to a lab for analysis....but don't have any idea what lab or even what kind of lab. Maybe someone here knows.
But it sure looks like something is breaking up. A magnet to start, and then a microscope might tell you something.
Have you got a used power reverser clutch plate that you could look at? And some wet brake plates too if yours has that.
Look at your attachments also. They may be contaminated.
The only attachment I have used is the dealer installed loader. Never been off the machine.
I did replace a shifter boot last winter but there didn’t seem to be a way for dirt to get into the transmission, the linkage seemed pretty tight. The tractor is very clean and stored inside.
They are wet brakes. I’m going to give the sample to Deere to see what they think.
   / Plugged hydraulic intake screen jd5055e #16
That's good. Everything you've said so far seems to point toward some component in the transmission is breaking up and particles being trapped by the filter.
From your picture and description I would suspect either the shifting clutches or the wet brakes - both of which can't help but shed particles when they work, though we don't know how much is normal.
With wet brakes, driving with the parking brake on is said to cause this to happen. I don't know if I've ever seen that, but it does make sense. On our JD a loud alarm goes off if I even start to engage a gear when the parking brake is on. On the Kubota it is perfectly possible to overpower the parking brake and drive away.
If it were mine, I'd want a second opinion from a formal automotive lab in addition to the dealer.
rScotty
rScotty
There is no parking brake on this tractor, it has a park position in the transmission.
   / Plugged hydraulic intake screen jd5055e #18
I don't know the details of the controls on the JD5055E, but I'm not sure we are on the same page here.
Are you saying there isn't any alternative way to manually actuate the brakes? Only the brake pedals? What do you do if the primary braking system should fail when you are cruising in road gear? Throw it into Park?
There are only brake pedals, no emergency brake. There is a park position on the transmission. The earlier versions had the same setup.
Update. I took the sample to my Deere dealership and they agree that it looks like either brake of clutch material. They are giving it to a service rep from Deere for analysis. The service manager agrees that it is unusual for this to occur in a machine with only 310 hours. Im hoping that Deere will cover the repair even if the tractor is 7 years old. There is a history of trouble with the hydraulic system going back to the first two years when it was under warrantee. We will see what they say.
Caterpillar 4 Cylinder Engine (A53316)
Caterpillar 4...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
6' 3Pt. Blade (A53316)
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55788)
2013 Ford F-150...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
2025 Wolverine SBM-12-72W 72in Sickie Bar Mower Skid Steer Attachment (A55787)
2025 Wolverine...
