Plumbing 201 question, use all copper or iron?
   / Plumbing 201 question, use all copper or iron?
Freudian slip perhaps?
/forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif
   / Plumbing 201 question, use all copper or iron? #12
You want the 707-3-5 drop 90. You pick a nipple and set the depth by where you mount the header that you attach to. It will work for your basic shower head as well. I will repeat, use brass nipples. Copper pipe can twist off if you try to turn it hard enough to seal a threaded joint. Pulling a slab of tile isn't a project you want to add to yout list.
   / Plumbing 201 question, use all copper or iron? #13
<font color="blue">><font color="blueclass=small">( I will repeat, use brass nipples. Copper pipe can twist off if you try to turn it hard enough to seal a threaded joint. Pulling a slab of tile isn't a project you want to add to yout list. )</ </font>
Usually will never happen if you turn it by the fitting and NOT the pipe. Since I can't see the project in person, I suggested that there are options available. Not uncommon for me to set an adapter and piece of pipe in a joint like that (as a stubout)and then "finish" as necessary when the tile / drywall is done.
   / Plumbing 201 question, use all copper or iron? #14
Glad to help. Where are the pictures that your wife sees?
They don't appear on my version of TBN , which upgrade feature do I ask for? /forums/images/graemlins/grin.gif
</font><font color="blue" class="small">( You want the 707-3-5 drop 90. You pick a nipple and set the depth by where you mount the header that you attach to. It will work for your basic shower head as well. I will repeat, use brass nipples. Copper pipe can twist off if you try to turn it hard enough to seal a threaded joint. Pulling a slab of tile isn't a project you want to add to yout list. )</font>
I've called Nibco, they won't sell to end users. I've called ALL the local Nibco vendors and they only seem to have the 1/2" x 1/2" drop elbow.
Any ideas on where one might obtain a 3/4"x1/2" drop elbow? (Nibco DOES make it but they won't tell me who orders them so I'm up to my fingers & yellow pages /forums/images/graemlins/tongue.gif )
I know I can reduce down to it but if the "right" part is out there, I always try to use the "right" part even if it's a bit more effort on my part which this is clearly turning into.
2016 Sure-Trac 20 Ton Pintle Trailer, VIN # 5JW2U2522G1121114 (A51572)
2016 Sure-Trac 20...
Approximately 250 Traffic Cones (A51573)
Approximately 250...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
2010 Chevrolet Impala Sedan (A51694)
2010 Chevrolet...
2015 PETERBILT 367 SLEEPER (A52576)
2015 PETERBILT 367...
