Gary Fowler
Super Star Member
- Joined
- Jun 23, 2008
- Messages
- 11,917
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
Having to do all the greasing by myself, I bought a $29 pneumatic gun at Atwoods (dont know the brand) but it has worked as it should for over 8 years. The LocknLube wouldn't work in lots of places on my TLB so a regular lock on tip is required. Since most times you need to hold the tip onto the zerk the pneumatic is a requirement. I wont ever part with the money to buy a battery powered one for many of the reasons listed.
I have a powered roll up hose attached to my hotdog tank air compressor. It pumps up very fast and the only time I have trouble with the gun is when changing grease tubes. I almost always have to un-screw the hose at the gun to allow it to pump out the air that invariably gets trapped in the gun. Once primed, it pumps till the end of the tube with no problems. I can tell by the sound if it is pumping grease and when the tube is finished it starts pumping really fast. If the zerk isn't taking grease, it pumps up then stops or cycles in 10 second or so intervals.
I keep the hand pump ready in case I need just a shot of grease on bolt threads or other such project that just needs a really small amount of grease.
The pneumatic has quick couplers on it so it is just a matter of connecting the hose. I flip the switch on the compressor when I enter the shop, pick up the gun, attach the hose, walk to the tractor while pulling out the required amount of hose and locking the HF retractable hose reel. By the time I am ready to grease, the compressor is up to pressure. I can grease the 20 or so zerks, uncouple the gun and let the hose retract, put up the gun and be ready to go to work in 10 minutes or less.
I would never go back to a hand pump grease gun.
Note: I wouldn't bother with the HF pneumatic guns. My brother in law bought one and it never worked quite right.
