scdeerslayer
Thankfully I don't react as badly to it as I used to.  For the bushes, spray with brush killer and mow 10-14 days later.  The vines I do the same as you cutting them off with a pole pruner.  I cut out a section of several inches, to make sure it doesn't grow back, but I don't know if it could but I like to be sure.  I just leave the vines in the trees though, I don't see the need to remove the vine unless I'm putting a deer stand in the tree.  In that case I use a machete to cut off however high I need it removed, then pry the remaining vine off of the tree with the machete.  Spraying the vine stump is probably a good idea.  Spraying the vine probably isn't a good idea unless you can spray every leaf.
