pole barn: cutting metal on slop for gable end wal
   / pole barn: cutting metal on slop for gable end wal
to Bird and anyone i PM'd, i posted the question here first and then figured i might get a quicker response if i just pm'd you, so i wasnt trying to verify the answer or anything like that, i just needed a real quick answer as i am planning on starting the siding today, guess i should have erased this reply after i pm'd yall.
   / pole barn: cutting metal on slop for gable end wal #22
No problem at all; I just couldn't resist kidding you a bit. /forums/images/graemlins/wink.gif Good luck with the project.
   / pole barn: cutting metal on slop for gable end wal #23
38" run on a 4/12 pitch will give you a 1-0 43/64 rise or you could round it off to 1-0-11/16
   / pole barn: cutting metal on slop for gable end wal #24
Your making this more complicated than it is. Just measure from the rat guard to the top where your sheet will overlap the other. Then move over 38" & measure where the sheet will end. Transfer those to the sheet you are putting up. You don't have to be exact because your trim will cover some.
   / pole barn: cutting metal on slop for gable end wal #25
easiest way is to measure center to center on ridges for 36 " covered panels. straight line left to right, then on the high side ( toward gable point) measure up one foot, make mark in center of ridge, connect the dots with straight edge draw line and cut. simple see. guys some people dont have all the building skills needed so its best to use the old analogy of KISS ( keep it simple silly) :)
2016 Takeuchi TL10V2 Compact Track Loader Skid Steer (A55851)
2016 Takeuchi...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2015 Peterbilt 320...
2006 TK Equipment CM9 Towable Concrete Mixer (A55851)
2006 TK Equipment...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2018 K-TEC 1228 PULL TYPE DIRT PAN (A52707)
2018 K-TEC 1228...
Honda EM3500S Generator (A55851)
Honda EM3500S...
