pole barn: cutting metal on slop for gable end wal
   / pole barn: cutting metal on slop for gable end wal #11
Egon messed up as usual. 4/12 = 1/3
Seems the story of my life lately. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Egon
   / pole barn: cutting metal on slop for gable end wal #12
egon,
That's "not" usual for you.That's why I had to read it 10 times before I posted.Then I still wasn't sure. /forums/images/graemlins/grin.gif
These are 3' wide panels, dont want to mess them up, thats for sure, i already messed up the cut on 2 roof panels..
   / pole barn: cutting metal on slop for gable end wal #14
Mopower440,
We just put up a 40x60 steel building a short time ago, and one of the things we found was cutting the metal siding was not easy.
We found two methods about equal, depending upon which way you are cutting.
1) 4.5" or better 9" portable grinder with CUTOFF wheel. NOT grinding wheel which takes too much material and more time. Be sure to get good reinforced wheels.
2) We bought a pair of air shears. These are not the air nibbler we already had which only take a small bit. The shears actually look like scissor or tinsnip blades. These saved a tremendous amount of time, but can't always cut across ridges. They are great for the long, flat cuts.
I figured after you determined and marked your cut, the actual cut might give you some trouble...
-JC
   / pole barn: cutting metal on slop for gable end wal #15
I flip the blade on a Skil saw and use that. Wear eye and hearing protection, it's noisy and hot metal flies everwhere.
   / pole barn: cutting metal on slop for gable end wal #16
I cut all my steel with straight cut long bill snips. You can buy the them at sears. They look just like the small aviatin snips with longer blades. The easiest way to cut gables is to simply use your 12 inch speed square. I always cut starting at the overlap end. get your length then put your square on the mark then rotate the square to your slope (keep the pivot point at the mark and rotate square to the the number 4 on the common scale) mark with a pencil then use a straight edge to continue your mark. If you use saws, abrasive blades, etc it tends to generate heat and will burn the paint then your ends will rust fast. With a little practice you will be very fast and efficient. After you cut one sheet measure the long or short side of the piece you just cut. Depending on which way you are running (up or down) then you have your measurement for the next sheet. I always wear leather gloves. Pull the scrap piece that you are cutting up with one hand and you wont have any problems. I set two 16 foot 2x4s across my saw horses for a work station. Good luck Glenn
   / pole barn: cutting metal on slop for gable end wal #17
They have abrasive saw blades for circular saws. That is all we will use on a barn. No sense messing around with shears or anything else as they all take way to long.
ok, i understand that for my 4-12 pitch, i need to cut 1 foot for every 3 ft across, 3 feet would be 36", these metal panels i have are EXACTLY 38" wide, so can someone tell me exactly how much to cut for 38"? should be a hair over 1'..?
   / pole barn: cutting metal on slop for gable end wal #19
Hmmm, I just answered this in a PM, and now you're going to try to get someone else to verify my figures (and I don't blame you a bit). /forums/images/graemlins/wink.gif /forums/images/graemlins/laugh.gif It's best to double check and measure twice. /forums/images/graemlins/laugh.gif
   / pole barn: cutting metal on slop for gable end wal #20
Make Your measurements at the center of the two outermost ribs . You'll find that to be 36 inches . Hope that makes sense and helps . John
2003 Ferris IS1000 52in Zero Turn Mower (A51694)
2003 Ferris IS1000...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
Kubota L4701 (A53317)
2024 Bintelli ActivEV Pulse Electric Cart (A55853)
2024 Bintelli...
3012 (A55851)
3012 (A55851)
