Pole Barn Loft...framing size questions
   / Pole Barn Loft...framing size questions #1
Zebrafive
Super Member
South West MI
John Deere 2030, John Deere 6415
I want to build a loft in my pole barn. I would like it to be 30' wide and 12' deep.
My plan is to attach a 2 x? board across the rear wall for 30' to attach joist hangers to. Then on the side wall attaching to the first post will be a 2 x ? laminated beam (built on site) , 30'. It will be supported by adjustable steel post(s). My floor is 6" reinforced concrete. The joists will be 16" on center. They will be mounted on top of the 30' laminted beam, cantilevering past it approx 2 1/2' (my side wall posts are on 9' centers)
Joists will have X bracing at mid point. Loft floor will be 3/4 plywood screwed and glued.
Shelf units would be installed and only items light enough to hand carry would be stored up there.
Now my questions:
1 What size joists for the 12' span? It will cantilever for approx 2 1/2' of the 12'
2 What size board for the joist hangers that will attach to the poles on the rear wall? Should it be two layers ?
3 What size boards for the 30' beam? How many layers? I would not be opposed to more layers if I could drop down a size in lumber.
4 Or would a steel beam be better? Is so what size? How would cost compare to laminted wood?
5 How many adjustable steel posts? Will two on 15' centers be enough? Plus the side wall post for total of three?
6 Any suggestions, ideas?
   / Pole Barn Loft...framing size questions #3
In using ustmd's linked calculator, you will want to enter the distance between support points as the span, not the length of your joists. If I understand correctly, this will just be 9 ft 6 in for you. My look at the calculator shows you could get away with 2x6 joists, but you might want to use 2x8 since the cost isn't much more and that would give you lots of margin for storing heavy loads.
A single 2 x ? on the rear wall will be enough. If you are using joist hangers, a second layer won't help. I have often seen the hanger plate one size larger than the joists (e.g. 2x8 joists, 2x10 hanger plate) but it only has to be the same size. I'm old school and for this application probably wouldn't use joist hangers. I would just rest the joists on top of the support plate.
For the beam away from the wall, I would suggest going to a building supply store and have them see if they can get you an engineered beam (truss, i-section, or laminate) rated to span 30 feet. It would be nice to do away with the posts completely. If you can't get a wood beam, you could check out an I-Beam. However, I did a quick back of the envelope calc and I think you would need at least a 8 inch and perhaps a 10 inch I-Beam for this application. That would get it up to the 600 to 750 lb range for a 30 foot beam which could be more than you want to handle.
If you go with posts, I would still recommend buying some type of engineered beams. I would suggest 6x6 timber posts, well braced. One final thought - adding ties from the roof truss down to the spanning beam would stiffen things up considerably. The only caution is that it adds some load to the trusses and pole barn trusses don't always have much margin. However, you might think about some vertical boards that are secured to both the rafter and joist members of the truss and come down to hook to the beam or joist of the new floor.
   / Pole Barn Loft...framing size questions #4
I sunk a post in the floor before I poured my concrete and then attached it to the truss overhead for my loft. I used a 2x8 nailed to my back wall and then hung joist hanger on it and set my 2x6 joists on top and then laid my flooring on top of that. Here is one pic showing the post and placement just after I finished my project and before I even got my joists up. I've since put in a second loft on the other side and built some stairs to make it easier to access. I will work on getting a few more pics for you.
http://www.tractorbynet.com/forums/...-my-30x40x12-pole-barn-thread-10-26-10-10.jpg
   / Pole Barn Loft...framing size questions #5
Here are a few more pics
Thanks for the replies.
The calculator and KennyG confirms 2x6 is minumum for joists. I agree 2x8s is a better option.
My thought on doubling the the rear wall joist hanger was less deflection between each rear wall pole. Might be overkill. A ledger board would save the cost of joist hangers. I think I will go that way.
I am not sure how to use the calulator to size the 30' beam. No posts would be great. I prefer to build it on site out of 2x? lumber. I do not want to tie into the roof truss. My thought on using steel jack posts would be the adjustablitiy if my concrete floor is not perfectly flat/level. I am thinking four 2x8s or 2x10s.
   / Pole Barn Loft...framing size questions #7
Zebra, If you are going to use dimensional lumber for your beam you can not span 30' without posts. To minimize the number of posts you would be better off using a double 12" LVL, as far as the ledger board along the back I would use a single LVL attached with LedgerLock screws. Then set your 2x8x12' floor joists, be sure to use joist hangers along rear ledger. If you go toyour local lumber yard they can help you with sizing and post spacing. Good luck.
   / Pole Barn Loft...framing size questions #8
I agree that the 30' span is not going to work well using dimensional lumber. Even one post in the middle would make it more doable. The LVL beams would be your best bet by far if you can't bring yourself to set a post. The steel jack posts do not meet code in many areas. This may or may not be a problem for you. Also, many lumber yards that deal in LVL beams have engineer computer models that will calculated the appropriate size needed. The box stores don't offer that service, at least here.
MarkV
   / Pole Barn Loft...framing size questions #9
Here's my best guess at this:
If the loft is going to be 12' x 30', this should be 360 sq. ft. Figuring a live load of 40 PSF and a dead load of 10 PSF, we should have a total maximum load of 18,000 lbs. Half of the load (9,000 lbs) will be bearing on the existing wall, so we only need to size your support beam for about 9,000 lbs. Here's a couple of options that I have come up with:
1. With 1 post in the middle, the load on each side will be 4,500 lbs. A single 2x10 will carry about 1145 lbs over 15 ft. A single 2 x 12 will carry about 1695. It looks most likely to got with a beam made of tripled 2x12s would be the best option, although you could probably go with a quadrupled 2 x 10.
2. If you go with steel, with no support in the middle, you will need upward of a 15" x 43 lb I beam or a 10" or 12" wide flange beam (poundage varies). According to the span tables I'm looking at, they will support a whole lot more than 9,000 lbs, but the smaller beams aren't recommended to span 30'. With a post in the middle, you could probably get away with a 6" or 7" I beam or a similar sized wide flange.
3. I don't have any idea what type of engineered lumber beam you would need, but you can ask someone to size a 9,000 lb load over a 30 ft. span and they can probably tell you. I bet it will be a lot better to have a post in middle, no matter what you do.
Good luck and take care.
   / Pole Barn Loft...framing size questions #10
I would build a truss (going up) to support your storage aera.Not spend lots of $ers on a carrying beam.I would build the truss in place.Use it to hold your floor,, just my $00.02
Army grunt
I am thinking for the beam to put a 6 x6 post in the center then from the wall posts double 2 x 10s on each side of of all the posts (total 4, 2 x10s). Use Ledgerlok screws at the posts, liquid nail between the 2 x10s, then 3" deck screws in vertical rows on 2' centers on the 2 x 10s. Staggering the joints in the 2 x10s so there will not be any joints inline
   / Pole Barn Loft...framing size questions #12
A few thoughts for what it's worth. There are lots of ways to do these things. I would build a continuous beam for the 30 foot span and I would let it rest on the top of the 6x6 rather that fasten beams into the sides. If you build the beam that is three layers of 2x10's, with two layers of 1/2" plywood laminated it will be the same width as the 6x6. Then you can add some angle braces on the face of the post and beam. This beam will probably end up in the 400 lb range but it will be very substantial.
As far as the loading, the 40 psf live load and 10psf dead load is pretty standard code for occupied spaces. However, if you're building this for your own storage use, you can design it for a lower load. I would guess it's really unlikely you will ever store 10 tons of stuff in this area. So don't get too carried away with meeting code exactly.
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
2000 Thomas Built Saf-T-Liner Transit Passenger Bus (A59230)
2000 Thomas Built...
2009 MULTIQUIP 25KW GENERATOR (A58214)
2009 MULTIQUIP...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
2008 CHEVROLET C8500 DUMP TRUCK (A59823)
2008 CHEVROLET...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
